Timing
Old 07-04-2009, 08:30 PM   #1
1sikef's Avatar
Rep Power: 3 1sikef is on a distinguished road
Default Timing
Just picked up a 94' si for dirt cheap, the head was done, so i have a y8 head in my garage. i put it on and im running into timing issues. Z6 block with Y8 head, and im using y8 cam gear with z6 belt and its not working
so ive search and heard you have to use
- y8 cam gear w/ y8 timing belt.
or
- z6 cam gear w/ z6 belt.
or
- either belt w/ adjustable cam gear.
So which is true, i want to use oem stuff if possible, any help would be great
1sikef is offline   Reply With Quote
zc dohc timing. all timing marks line up, ignition timing is very retarded 91civicZCdohc General Tech and Maintenance 2 10-13-2008 06:35 PM
Difference between b16b timing belt and b18c timing belt ??? loverboy HYBRID -> EG-EK / DC 4 09-28-2007 10:49 AM
advanced timing v.s factory spec timing 90htchbck General Tech and Maintenance 6 04-19-2007 02:08 AM
advanced timing vs. factory timing 90htchbck HYBRID -> EG-EK / DC 0 04-17-2007 03:39 PM
Timing belt / timing gear problems swapdohc General Tech and Maintenance 1 05-25-2004 11:43 AM
