I started a project that kind of ended up over my head. Only because in the middle of this project I had a vacation planned, and upon returning I almost forgot where I was at. The project was replacing the head gasket, which led to having the head machined. One thing led to another, so of course I'm doing the timing as well. I have a 1991 Honda si hb and I'm wondering if I could install the timing belt without taking out the whole motor. I can see the I'll have to loosen a motor mount, but I want to know what is recommended?
¿GANGSTA GREMLIN?
Ride: 91 CRX si
everyone i know leaves the motor in,support the motor,take the mount off,jack it up,put the belt on,put mount back on and do timing
R.I.P BEN LEE2/24/08 we love and miss you http://burnoutbox.activeboard.com/in...BID=127652&p=1 GOOD FAST CHEAP, you can pick only two. fast and cheap isn't good good and cheap isn't fast good and fast isn't cheap |
| Tags |
| belt, replacing, timing |
| GSR timing belt kit, water pump, idler belt NEW | RSS-Bot | Auctions | 0 | 02-15-2008 12:03 AM |
| Difference between b16b timing belt and b18c timing belt ??? | loverboy | HYBRID -> EG-EK / DC | 4 | 09-28-2007 10:49 AM |
| Timing belt / timing gear problems | swapdohc | General Tech and Maintenance | 1 | 05-25-2004 11:43 AM |
| ZC timing belt??? | twotwo | General Tech and Maintenance | 8 | 04-25-2004 11:14 PM |
| Timing Belt In A 90 Si 1.6 | djyox | HYBRID -> EG-EK / DC | 2 | 04-29-2003 01:20 AM |
