toda cams
dean_mcl
I need professional help. i just ordered toda spec c cams from nengun.com and being that the description of the cams are so discreet i am not sure if the cams i ordered are toda spec c. i emailed them and asked them but all they had to say was just to check with a proffessional tuner. well here are the specs on the cams that were available.
Intake.
1411-B16-00A
Honda - B16A/B B18C - Valve Lift 220 (6.0) / 290 (11.6) / 240 (9.0) IN
14111-B16-00B
Honda - B16A/B B18C - Valve Lift 250 (11.0) / 295 (12.0) / 250 (11.0) IN
14111-B16-00C
Honda - B16A/B B18C - Valve lift 250 (11.0) / 295 (12.5) / 250 (11.0) IN
Exaust.
14121-B16-00A
Honda - B16A/B B18C - Valve Lift 220 (5.5) / 280 (11.2) / 240 (8.5) EX
14121-B16-00B
Honda - B16A/B B18C - Valve Lift 250 (11.0) / 285 (12.0) / 250 (11.0) EX
14121-B16-00C
Honda - B16A/B B18C - 250 (11.0) / 295 (12.5) / 250 (11.0) 250 (11.0) / 295 (12.5) / 250 (11.0) EX
naturally i choose b16-00C for intake and exaust assuming they are toda spec c cams..
What has me confused is that i have been comparing lift and duration from different sources and they all seem be different. if some one can just tell me which one of these cams are toda spec c cams i will apreciate it.
Also i am looking for a 68 or 70 mm throttle body (bbk or skunk 2)
you can send me eamils at dean_mcl@yahoo.com
