Facebook Twitter
Toda spec B camshafts
This is a discussion on Toda spec B camshafts in the Engine Building forum
I can get the Toda Spec B camshafts with Type r valvesprings and port flow retainers for $750 Is this a good deal? Also what do you guys think about using the type r springs rather then the toda springs like they recommend? These cams ...
Old 07-23-2004, 12:40 PM   #1
Is this a good deal? Also what do you guys think about using the type r springs rather then the toda springs like they recommend? These cams will be going into a b20 vtec and only revving to about 8k max, what do you guys think about clearance issues? The head has been milled because of a blown head gasket.
Thanks
Khai
khai_tuan_nguyen is offline   Reply With Quote
Old 07-23-2004, 05:22 PM   #2
any ideas?
Old 07-23-2004, 06:40 PM   #3
B16
B16's Avatar
i wouldn't run those springs with those cams... i know what deal your'e talking about, i wanted to buy the cams themselves get it and sell the retainers and springs, pick up some toda springs oem retainers and toda sprockets and call it a day
B16 is online now   Reply With Quote
Old 07-25-2004, 04:38 AM   #4
2000Si's Avatar
Originally posted by pheonixb16aguy@Jul 25 2004, 03:57 AM
[b]jeff at ib has dyno to prove his cams are the SHIIIAAT
is that stated in the guarantee too? :P
2000Si is offline   Reply With Quote
Old 07-25-2004, 02:36 PM   #5
good info, I didn't even know that IB now makes cams...have to check out their new page.
Old 07-26-2004, 09:13 PM   #6
Originally posted by khai_tuan_nguyen@Jul 23 2004, 12:40 PM
[b]I can get the Toda Spec B camshafts with Type r valvesprings and port flow retainers for $750
Thanks
Khai
EDIT.. you neet to switch the inner springs...see 2 posts below after reading this one..lol
Yes thats a really good deal.. I ran that exact spring combo with my toda b's for 2 years with no problems except breaking a timming belt in the end. I also ran them in my first 2ltr with the original IB spec pistons 7cc , pistons were at 0 deck with no clearance issues at all. I put down 220 with that setup
Tbone is offline   Reply With Quote
Old 07-26-2004, 09:57 PM   #7
B16
B16's Avatar
Originally posted by Tbone+Jul 26 2004, 06:13 PM-->
Originally Posted by Tbone @ Jul 26 2004, 06:13 PM)
khai_tuan_nguyen
Thanks
Khai
so you can run spec b's on ITR valvetrain? i thought the lift would be too much. how high did you rev that motor? hmm... i'd like some b's :P
2009 Mercedes Benz C63 AMG
2000 Mercedes Benz ML 430
Old 07-26-2004, 11:03 PM   #8
OPPS I read it wrong, you need to switch your inner springs to portflow as well. So itr outers with portflow inners
© 2001-2013 HondaSwap.com
