Turbo B16 Vtec
Old 04-08-2003, 09:56 AM   #1
ChaseRsX is off the scale
I am building up a b16 block to hold 20 lbs or more of boost. I am boring the sleeves out to 84mm and using a b17 crank and rods. I have a couple questions about this build up.
1. I know I need to get the block resleeved. I have heard of golden eagle doing it and I have also heard of JG making bored out, solid deck blocks. Does anyone know anything about these two products?
2. If I use that crank, do I use a flywheel and clutch from a b16, a b17, or are they the same?
3. I am putting this motor into a 91 crx. The car has a 91 ls motor in it already. Can I use the cv joints from the ls on the b16?
ChaseRsX is offline   Reply With Quote
Old 04-08-2003, 11:25 AM   #2
88 C1V1C 53D4N DR1V3R
saturn_boy96's Avatar
Ride:  2006 Suzuki Aerio
saturn_boy96 will become famous soon enough
Send a message via AIM to saturn_boy96 Send a message via MSN to saturn_boy96 myspace
1. golden eagle is probably the best, dart makes the solid closed deck blocks, but they are expensive.
2. the clutches are the same, but go with an aftermarket on to hold the power of the boosted motor.
3. you can use everything from the tranny down if they are both cable actuated.
saturn_boy96 is offline   Reply With Quote
Old 04-08-2003, 11:30 AM   #3
Ride:  '92 Civic CX
D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
nope, the 90-91 b16 tranny and the 92-93 gsr tranny have a different number of splines on the input shaft. so the clutches are NOT compatible.
as far as the flywheels go, all b series flywheels are interchangeable.
D See 2 is offline   Reply With Quote
Old 04-10-2003, 04:08 AM   #4
Slo86GT's Avatar
Slo86GT is an unknown quantity at this point
Send a message via AIM to Slo86GT Send a message via MSN to Slo86GT Send a message via Yahoo to Slo86GT
Not a different NUMBER of splines, just a different diameter of splines.
Trust me, I know. I've gottem em mixed up and cursed their splined asses.
Slo86GT is offline   Reply With Quote
Help with turbo on stock Honda CRX 1.6 VTEC B16A JOeS Forced Induction 10 06-01-2004 01:17 PM
Turbo B16 mattcalica Engine Building 12 07-19-2003 11:31 AM
Turbo Lude Not Likin Vtec eicivic HYBRID -> BA-BB /CA-CD 13 03-14-2003 08:01 PM
Turbo cam gears for a VTEC Silverchild79 Forced Induction 7 12-27-2002 03:51 PM
LS-VTEC/CR- VTEC Info pissedoffsol General Tech Articles 1 11-10-2002 03:19 AM
