i just dropped off gsr rods with type r pistons at a machine shop and asked them to press ls rods to the pistons...well i got a phone call today, they said that they would have to machine the rods to make them fit.....i thought that sounded odd.....so i'm wondering if anyone heard of that or are they trying to get more money out of me?....haven't people used type r pistons in ls blocks before?...thanks
I'm new to the game but learning quick....thanks for all the help guys! 94 Lude many mods (h23) 94 CX B18b 93 DX with '95 b18c ls/vtec w/ type r pistons and crower valve train 97 Toyota Tacoma (to transport all my parts) 89 Nissan 240sx (someday project) |
#2 | |
Member of the 20 nut club
doesnt work
МОΛΏΝ ΛΑΒΈ |
well wat the machine shop did to my ctr or itr piston to fit on my ls rod was to remove 1 mm of material on each side of the small end of the connecting rod in order to have sufficient clearance where the rod meets the piston.. but i think it weakens the rods... just cant revv to high..but are you puttin it in a non vtec motor, ls vtec motor, or vtec motor??
Menace 2 Society!!!!! Rides That Excite!!!! www.ridesthatexcite@groups.msn.com www.geocities.com/m2sridesthatexcite |
#5 |
basically its going in a gsr block with an ls crank.....the only reason i'm doing it is to run an all motor setup until i can gather together everything i need for turbo which probably won't be till the spring after this....right now i bought the car completed the engine from scratch so it put a dent in my wallet.....when i rebuild it i'm gonna put in low compression je pistons and probably eagle rods
#6 |
if you're going to turbo down the road, why waste your money on N/A parts?
2005 Mitsubishi Lancer Evolution 8 2004 BMW 325i 2000 Mercedes Benz ML 430 1994 Honda Civic Del Sol VTEC (race kaa) |
#7 |
i had ITR slugs machined to fit on my LS rods and i had em press in some ARP rod bolts for extra security. i've heard of plenty of ppl spinning to 7500rpm w/ LS rods. i wouldn't go any higher on a stock head tho...
Fate only takes you so far. Once you're there it's up to you to make it happen. |
#8 | |
and the head is not stock. __________________
| B20B Vtec Aftermarket pistons and rods | khai_tuan_nguyen | Engine Building | 2 | 06-15-2004 12:20 AM |
| My new pistons and rods... | Calesta | Engine Building | 8 | 03-08-2004 02:50 AM |
| Want A High Revving Monster? | maverick97 | Engine Building | 10 | 06-26-2003 04:25 PM |
