Valve to Piston Clearance, Type S Pistons In The H23
Old 03-25-2008, 11:53 PM   #1
DAM!!!'s Avatar
Rep Power: 4 DAM!!! is on a distinguished road
Question Valve to Piston Clearance, Type S Pistons In The H23
I know there's a lot of threads out there on this subject and everyone I've read isn't really convincing me if I should or shouldn't do it.....some people say there will be no problem with valve to piston clearance, and then some say that they will make contact cause of the dome hight on the pistons, and some say to just use a thicker head gasket to prevent the valves from hitting the pistons...then theres talk about I will need to upgrade my camshafts cause of the higher comp (12.5) and even get a stronger valve train... then a lot of other stuff about good, and then bad, but I dont want to get into it...So im just asking what I need to know and hopefully it's more positive then negative...
Would I be able use the type s pistons on Crower Rods (h23) with out the pistons hitting the valves??
Will the H22 rods be better to use with the type s pistons in the H23, rather then the h23 rods with type s pistons?
Which will give better valve to piston clearance but still keeps the compression high, H22 OR H23??
Can a thicker head gasket really work if the pistons hit the valves???
Any additional info that I will need to know please inform me.
DAM!!! is offline   Reply With Quote
b18a1 With B17 head type r cams piston clearance. JDM-JAMES Engine Building 6 03-05-2008 12:29 AM
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 09:26 PM
ctr piston clearance vwhondahatches Engine Building 2 12-24-2002 09:03 AM
milling your head? djextremity General Tech and Maintenance 5 11-13-2002 11:11 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
