Vitara's and a d15b
Old 07-04-2008, 12:31 AM   #1
Rep Power: 10 stuntstere is off the scale
Default Vitara's and a d15b
Hey guys i have a D15B jdm vtec i recently rebuilt.. ported head, supertech valve springs and retainers, crower stage 2 cam, y8 aem cam gear, arp rod and head bolts, and basic bolt ons tuned on crome... and this is what happened after my retainer broke and i dropped a valve....
Now i am going to rebuild with eagle rods a vitara's if i can. the only thing i was wondering if i will run into any problems with them.
P08-dome(-4.5 cc), compression height(27.4 mm), piston to deck height (-0.016)
vitara- (-15 cc) (28.3 mm) (-0.052)
I used the calc from zealautowerks.com for the specs.. I guess my question is will i have any compression height issues with the vitara pistons?
Thanks for the help
stuntstere is offline   Reply With Quote
Old 07-04-2008, 12:38 AM   #2
Honda Enthusiast
Luis998's Avatar
Ride:  '94 EG sedan w /Z6, '97 EK hatch
Rep Power: 68 Luis998 has a reputation beyond repute
Luis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond reputeLuis998 has a reputation beyond repute
Yes. Your compression will drop to I believe 7:8 or somewhere around there with any other type of rod besides FJT's custom i-Beams, which actually bring up your compression to 8:8. I've read a lot of articles about Vitara's and I got the information straight from FJT's posts in other sites. Here is the link to the site...FJ Distributors
This next link shows the thread started in TurboD16.com that talks about the custom i-Beams. There is a really good thread on that site that actually tells about the compression bump with the custom i-Beams, which you will be able to find. Turbo D16 • View topic - 2nd batch: Custom Forged I beam rods. Official List
Best of luck on your rebuild and I hope that I was somewhat helpful to you.
Max? There is no max. Max just means you gave up.
This is my thread: http://hondaswap.com/engine-building...g-wind-110848/
My for sale/trade thread http://hondaswap.com/parts-sale-trad...1/#post1048406
Originally Posted by Blanco View Post
Headers and a turbo, eh? Brilliant advice, Doctor. Simply brilliant.
Originally Posted by LS_VTEC View Post
lol... you could say that doing it right will "get you bitches". ;x
Originally Posted by efhondakid View Post
"Im so JDM I sleep on the right side of the bed"
Luis998 is offline   Reply With Quote
Old 07-04-2008, 01:08 AM   #3
Thanks for the help... but correct me if i am wrong... i figured that the vitaras would stick out too far on the d15 but if i go custom with the rod and lower it won't it effectively lower the compression with it? and the rods i seen that they were selling were for the d16 and they are roughly 1.5 mm longer to get the piston up in the d16. Do they have a shorter rod for the d15?
Old 07-04-2008, 01:10 AM   #4
Honda Enthusiast
Luis998's Avatar
You know, you may have something there. haha Check around TurboD16.com for threads started by FJT. I BELIEVE he talks about D15b's somewhere in them and explains everything for you. If not, check out the site as I have only really looked for information on Z6's and Y8's.
Old 07-04-2008, 01:18 AM   #5
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 88 K2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud ofK2e2vin has much to be proud of
Send a message via AIM to K2e2vin
FJT actually has shorter rods for the D15B.
You should be fine btw. CR is like 8.2
1988 Honda Civic STD-more mods than I want to list
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
K2e2vin is online now   Reply With Quote
Old 07-04-2008, 01:24 AM   #6
thanks for the help... so do you think i would be ok with the stock rod lenght on the motor? even though the vitara's will sit slightly higher in the block?
Old 07-04-2008, 01:27 AM   #7
Honda Enthusiast
Luis998's Avatar
Thanks for the compression info, Kevin. Rep! I wouldn't learn anything if others wouldn't teach it just like that.
Old 07-04-2008, 02:47 AM   #8
K2e2vin's Avatar
They should be fine; the top of the piston goes up only about .9mm from stock, and sticks up about .55mm. The stock headgasket is about 1mm thick; plus there's extra volume in the combustion chamber(vs. a Y8 head that has the quench pads).
BTW, I'm working on a build that has the pistons sitting much higher(roughly .9mm above deck...flat top pistons) Don't know if it'll work yet.
RIP
Old 07-04-2008, 09:54 AM   #9
Alright thanks... i wasn't for sure if that little bit would create any problems...
Forum Jump
d15b ReDCiViCSi Vehicles: For Sale/Trade/Wanted 4 12-06-2007 10:59 AM
Jdm D15b Vitalspeed_CRX Civic and CRX - EF 5 05-23-2007 07:30 PM
D15b Help!!!! babybluecivic General Tech and Maintenance 4 05-16-2007 05:59 PM
d15b help? vi3tromanc3r Engine Building 2 03-31-2006 08:22 PM
d15b bigdaddyIII HYBRID -> EG-EK / DC 28 12-22-2003 10:44 AM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
