Facebook Twitter
wat compression for buddy clup spec 3 cams
This is a discussion on wat compression for buddy clup spec 3 cams in the Engine Building forum
ive got a stock b16a2 in my sol, and if i were to get some buddy club spec 3 cams what is the minimum compression i should be running????? also with the cams i will have buddy clup dual springs, cam gears, skunk2 titanium retainers ...
Old 02-17-2008, 05:57 PM   #1
Wilshire's Avatar
Default wat compression for buddy clup spec 3 cams
also with the cams i will have buddy clup dual springs, cam gears, skunk2 titanium retainers and 1 mm oversized flat valves, and also a mild port and polish.
thanks in advance
Wilshire is offline   Reply With Quote
Old 02-17-2008, 06:33 PM   #2
K2e2vin's Avatar
I'd say 10 and up would be fine. The III's are more equivalent to ITR cams, and the III+ are suppose to make a little more.
Old 02-17-2008, 09:10 PM   #3
Wilshire's Avatar
k thanks, im going with the spec III plus'. stock compression is 10.1-1 an with a thiner cometic headgasket and a little milled off the head i should have around 10.5 or so right???
Old 02-18-2008, 01:17 AM   #4
Wilshire's Avatar
would valve clearance still be an issue if the shop im going through is gonna preform a vlave job to compensate for the larger valves??? prolly a stupid questoin but... oh well
and yea there going to do a mild port n polish, including port matching the intake runners to the itr mani i got
Old 02-18-2008, 02:10 AM   #5
K2e2vin's Avatar
If you're running larger valves, then you definitely want to clay the motor to make sure there's no contact. The shop should be able to do it for you(if they're building the whole engine for you).
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 08:26 PM
FS: 5 sets of cams...in socal. acydphryck Parts: For Sale/Trade/Wanted 10 05-21-2004 11:35 PM
toda spec b cams jessevtec Parts: For Sale/Trade/Wanted 0 08-16-2003 05:31 AM
Skunk2 Vs. Spoon Camshafts wisemansoji Engine Building 3 05-11-2003 04:20 PM
LS-VTEC/CR- VTEC Info pissedoffsol General Tech Articles 1 11-10-2002 03:19 AM
© 2001-2013 HondaSwap.com
