| | LinkBack | Thread Tools |
| | #1 |
| Member | Should I: 1) Buy the GSR drop-out for $3500 or 2) buy the LS drop-out for $2200 and use the other $1300 to buy a VTEC head? Warning: Ignorant question ahead! Isn't the head the whole difference between the two motors? I would love to be able to afford a Dart Block and build aftermarket from the oil drain plug to the valve cover. I know the parts are out there. Not because I'd be rich (or financially advantaged, in the interest of political correctness), but because I would be able to say that I built the engine that just embarrassed you.
__________________ KyEDHatch@hondaswap.net |
| | #2 |
| Super Moderator Join Date: Sep 2002 Location: New Albany, OH
iTrader: 0 / 0% Ride: 01 is300, 05 s2000, 03 rx300
Rep Power: 58 | if you buy an ls swap for 2200 you better get some sucky sucky or some bang bang with that. buy the gsr. if you want to build a proper ls/vtec it will cost more than the gsr one will (ASSUMING that you put new pistons/rods in it, and new valvetrain ) |
| | #4 | |
| Member | Thanks. Any ideas how I can con my wife out of the $3500? Quote:
| | #6 |
Rep Power: 58 | www.jbap.com yO! |
| | #7 |
| Junior Member | check out www.thepartstrader.com alot of people sell LS blocks their really cheap, no point in paying for the head if your not gonna use it...get a b16 tranny...it is the same as a type-r, except the LSD, but you can pick one up for a couple hundred bucks. |
| | #8 | |
| Banned | Quote:
| | #9 |
| Senior Member | I agree with pills, you might as well get the gsr. You cannot get a "properly" built lsvtec with the price of a gsr motor. In order to get a nice build up, you will need at least 5000 to have a decent setup. good luck. |
| | #10 | |
| Admin with a big stick Join Date: Sep 2002 Location: Dallas / Fort Worth, TX Age: 32
iTrader: 0 / 0% Ride: 2003 S2000
Rep Power: 392 | Quote:
| | #11 |
| GNU/Linux Evangelist Join Date: Sep 2002 Location: Greater Portland, OR
iTrader: 0 / 0% Ride: The Cheapest Road Bicycle I could get
Rep Power: 70 | Indeed, but if you do not start with the LS engine in the car the total cost will come out to at least the cost of the GSR swap, maybe a little more. Plus you have to like playing around in an engine to build an LSVTEC. You need to be comforatble taking every thing apart, and competent enough to get it all back together again. |
| LS/Vtec turbo? | UDT | General Tech and Maintenance | 5 | 11-20-2003 09:53 AM |
| LS/VTEC? or LS/Turbo? or both? | RFHOMI2U | HYBRID -> ED-EF / DA | 11 | 10-18-2003 06:27 PM |
| ls/vtec werd | KWJaY | Engine Building | 11 | 09-10-2003 04:39 PM |
| ls/vtec integra | silverfox | HYBRID -> EG-EK / DC | 5 | 06-30-2003 10:00 AM |
| Keep Gsr Or Go Ls/vtec | TegraTuner | HYBRID -> EG-EK / DC | 3 | 05-15-2003 09:13 PM |
