What else should I replace if doing head gasket?
Old 04-13-2004, 11:14 PM   #1
Rep Power: 11 ssl2k is off the scale
I'm getting a ZC that has a blown head gasket and I need to know what else I should do while i'm that far into the engine....
Going to have the head resurfaced and a new integra head gasket from a 89 integra....
But what else should I replace as far as gaskets and other things like that since i'm going to be that far into the engine.?
1991 CRX SI - Built D16Y8 - The piston melter
1990 CRX SI - B18A1 ... ls/vtec in the process y0
1988 Civic DX 4dr - d15b2 w/ mpfi + flaterate t-25 kit
ssl2k is offline   Reply With Quote
Old 04-13-2004, 11:15 PM   #2
BTW, I'm goingt o be running a 55shot dry on this engine...
Old 04-13-2004, 11:37 PM   #3
Rep Power: 27 rudeludenotmeanthough is off the scale
well, if you have the money, as it seems you do, you might as well get the intake mani gasket, and exaust gasket. But im sure you may have already thought about that, seeing as how it is sorta obvious.
</div><table border=\'0\' align=\'center\' width=\'95%\' cellpadding=\'3\' cellspacing=\'1\'><tr><td>QUOTE (94RedSiGal @ Dec 2 2003 @ 12:27 AM)</td></tr><tr><td id=\'QUOTE\'>Having a ClubSi, Honda-Tech or HondaSwap sticker on them would just scream &quot;Steal Me Now! I'm a special car!&quot; to thieves.</td></tr></table><div class=\'signature\'>
rudeludenotmeanthough is offline   Reply With Quote
Old 04-14-2004, 06:47 AM   #4
LOL
I wish I had a ton of money to play around with...I'm getting a trade on a zc for a d16a6 plus $100... that's this weeks pay check... then gaskets are next weeks check...then the zex kit is like another month down the road...
yeah i'll inspect the intake and exhuast gaskets and if they are bad i'll replace them....
i'm mainly wondering about like internal seals, valve seals...etc if they should be done...
How much does a valve job usually run?
nathan
Old 04-14-2004, 06:50 AM   #5
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 529 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
valve work insn't cheap.... andn chances are if you blew the headgasket, that they are still fine.
Old 04-14-2004, 06:59 AM   #6
I DonkeyPunch Hypocrites
B16RacerN2NR's Avatar
Ride:  06 Mazda 5, 92 BMW 318is
Rep Power: 107 B16RacerN2NR has a reputation beyond repute
B16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond reputeB16RacerN2NR has a reputation beyond repute
Send a message via AIM to B16RacerN2NR myspace
might as well do the timing belt and water pump
Now that Obama, a (half) Black man, is the President, I don't want to hear anymore about this so-called 'man' who's been holding your lazy ass back. Go get a damn job...
B16RacerN2NR is offline   Reply With Quote
Old 04-14-2004, 12:30 PM   #7
Rep Power: 17 cws13 is off the scale
Send a message via AIM to cws13
Check the taper on the bore and look for scoring down the side of the cylinder walls. Get an actual machined straight edge and ckeck the deck for warping too. These can and do warp from overheating. I still remember a prelude I had to do the whole motor on because the deck warped way more than the head when the gasket went. If this car blew a head gasket from higher mileage and/or overheating, and the bottom end is tired, you will get more blow by than when the car was running because you just tightened up the top end.
P.S. I would pass on the dry shot. Unless you are going to freshen up the bottom end, and even then wait for the wet one-preferrably direct port. I know it's way more expensive but I have just seen way too many motors fry #1 cyl from dry kits loading in front. Damn near new motors.
1320 Motorsports Athens,GA
<a href=\'http://www.1320motorsports.com\' target=\'_blank\'>1320 MOTORSPORTS</a>
cws13 is offline   Reply With Quote
Forum Jump
ls/vtec head gasket??? kell211 HYBRID -> EG-EK / DC 13 09-21-2008 03:20 PM
Head Gasket Repair (o)(o) General Tech and Maintenance 24 10-02-2007 12:09 AM
head bolts/throttle body gasket kingwilly General Tech and Maintenance 8 12-13-2006 12:49 PM
re-using head gasket Floydy Engine Building 6 06-04-2004 05:19 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
