What kind of powe will this put down?
Old 10-02-2004, 03:45 PM   #1
Rep Power: 0 r81gsr95 is off the scale
Honed, still 81mm bore
new oem honda bearings
all new seals of course
itr oil pump
gsr waterpump
bottom end balanced
polished crank
jdm itr pistons
b18c head
itr valvetrain
gsr cams
Port and polished
gasketmatched
valve job
intake manifold gasket match
with a jdm itr header, comptech catback, and aem short ram? uberdate tuned ecu. I'm waiting to dyno until i get my itr header on. What do you guys think? Thanks guys
r81gsr95 is offline   Reply With Quote
Old 10-02-2004, 04:04 PM   #2
Rep Power: 35 NotUrAverage_Si is off the scale
http://www.hondaswap.com/forums/index.php?showtopic=7
Originally posted by pissedoffsol
The only way to figure this out is to take YOUR car with YOUR mod to a dyno or track. There is no way to say that an ls/vtec with an aem CAI will make XXX horse to the wheels. it simply can't be done. There's too many variants in engines in the first place, plus other factors such as how it was built and tuned.
Remember, 2 stock motors will more likely than not dyno at the same figure, albiet it will be relatively close.
Basically, don't be upset when we say we can't tell you and to run it at a track or dyno. Afterall, estimates are usually wrong anyway.
We can't tell you. None of your friends can tell you. The only way to get a true number is to put your car on a Dyno, or go to the track and run it and compare your times/numbers.
Don't be upset when we tell you we can't say, and direct you here. We are just trying to keep things Legit and real :: no BS about "yeah you will run 9's".
'00 <span style=\"color:black\">FBP</span> Civic <span style=\"color:red\">Si</span>-T
|<a href=\"http://www.full-race.com\" target=\"_blank\">full-race</a>|<a href=\"http://www.goldeneaglemfg.com\" target=\"_blank\">golden eagle</a>|<a href=\"http://www.fast-turbo.com\" target=\"_blank\">fast-turbo</a>|<a href=\"http://www.hondata.com\" target=\"_blank\">hondata</a>|<a href=\"http://www.wiredspeed.com\" target=\"_blank\">wiredspeedlab</a>|
email: boostfedEM1@yahoo.com
<div class=\'quotetop\'>QUOTE(dohch22a4 @ Sep 20 2004, 11:44 AM)</div><div class=\'quotemain\'> Please, Obi Wan B, you're our only hope.
</div>
<span style=\"font-size:36pt;line-height:100%\"> <a href=\"http://www.nissantech.com\" target=\"_blank\">www.NissanTech.co m</a></span>
NotUrAverage_Si is offline   Reply With Quote
Old 10-02-2004, 04:17 PM   #3
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
4000 whp
Old 10-02-2004, 04:48 PM   #4
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
sounds 95% stock to me. expect 5% over stock numbers.
Old 10-02-2004, 06:42 PM   #5
Calesta's Avatar
Ride:  2003 S2000
I would guess 160whp
