I own a B18C6 engine (Euro Spec Integra Type R 1998) and the head's chambers have been welded and then cloverleaf shaped. The compression has been increased from 11.1 to 11.5. This is a slight increase, but the knock sensor is retarding my ignition and I lost lot's of power.
The local gas varies between 89 and 92 octane. When I added some octane booster the car's power on the dyno increased by 22 bhp at the flywheel!! What would be the best octane petrol to run in my car so as to maximise power. I don't want to add too much octane booster and end up with unburned fuel and backfires. Tnx ![]() |
Ride: 98 Civic EX Sedan S/C'd
I don't know if this is right, but if your engine is a Euro-spec type-R, I would run the hightest octane available at your local pump (92 octane most likely) because the car was probably running higher octane in Europe. When I was back in France the octane levels were 93, 95 and 98 if I remember correctly, the 89 octane-gas here in the states might be too low.
But then again I could be wrong... |
Admin with a big stick
Ride: 2003 S2000
Sounds to me like he's still in Europe somewhere. We don't call it petrol stateside.
![]() Run the highest octane you can get- although 92 should be fine for that compression ratio. __________________
| Drag kit install manual | pissedoffsol | Forced Induction | 0 | 07-18-2004 12:37 AM |
| research paper, what do you think? | 90 accord | Members' Lounge | 9 | 06-23-2004 12:11 AM |
| Fuel system | Sed8ed | Engine Building | 2 | 05-26-2004 01:05 PM |
| 1st Gen CRX FAQ's | pissedoffsol | Swap Articles | 0 | 01-12-2004 01:51 AM |
| Benefit of using Higher Octane? | pissedoffsol | General Tech Articles | 0 | 09-28-2002 01:37 PM |
