Whats A Difference In Obd1 And Obd2?
Old 03-17-2003, 12:47 PM   #1
Rep Power: 16 hondacivicnos is off the scale
Thumbs up
Whats a difference in OBD1 and OBD2?
And what do I have to do If I want to change my 95 civic EX which have OBD1 to OBD2?
And one more question B18C1 is OBD1 and OBD2 so how is it going to work?
Can I swap B18c1 without doing anything to my OBD1?
So here are some of my stupid question that I am trying to find aswer for. Please just answer them?
<span style=\'color:yellow\'><span style=\'font-size:21pt;line-height:100%\'><span style=\'font-family:Times\'>yo what up dawgs</span></span></span>
hondacivicnos is offline   Reply With Quote
Old 03-17-2003, 12:52 PM   #2
Rep Power: 25 SixtySecondAssassin is off the scale
94-95 b18c's are obdI
96+ are obdII
you can swap a 94-95 in your car no with no problems
if you get a 96+ you can use an obdI ecu, or you can use the obdII ecu with a jumper harness
.....deagle.....
SixtySecondAssassin is offline   Reply With Quote
Old 03-17-2003, 06:07 PM   #3
Thumbs up
yea I really want to use OBDII so were can I buy obdII ecu with a jumper harness swap for my civic?
Old 03-18-2003, 06:24 PM   #4
Rep Power: 17 solblu is off the scale
Why do you want to use OBD2??
Your car is OBD1, there is no reason to make it OBD2.
Yes you can swap in an OBD2 engine without changing to OBD2. You need to get OBD1 ECU, Injectors, Engine Harness, and distributor. You can use the OBD2 distributor and injectors if you change some wiring, but the OBD1 stuff bolts uo and is plug and play.
<a href=\'http://www.knology.net/~jediklc/\' target=\'_blank\'>My Webpage</a>
<a href=\'http://www.geocities.com/DawgSol94S/Welcome.html\' target=\'_blank\'>Team Sol Georgia</a>
solblu is offline   Reply With Quote
Old 03-18-2003, 07:14 PM   #5
Rep Power: 19 ek9r is off the scale
Send a message via AIM to ek9r
what he said, why would you want obd1 when obd2 is easier for you to obtain?
suck it sideways sister
ek9r is offline   Reply With Quote
Old 03-26-2003, 08:48 PM   #6
Rep Power: 14 93tegh22 is off the scale
what is the differins beteen obd1 and obd2?
93tegh22 is offline   Reply With Quote
Old 03-26-2003, 09:47 PM   #7
B16
B16's Avatar
my car is obdII and i made it obdI, trust me, you dont want to go obdII.
the difference between the two is what the ecu looks at, obdII is more strict, looks at more sensors, is more "smog" friendly than obdI. obdI is easier to tune.
2004 BMW 325i
2000 Mercedes Benz ML 430
Old 03-27-2003, 01:46 AM   #8
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
obd2 sucks.
keep your car obd1
the real difference is that there is a 2nd o2 sensor after the cat.
other than that, its the plugs that are different.
if you have an obd2 motor to go in, its not too hard to make it obd1. run an obd1 ecu, and swap out the plugs from your d-series harness for the most part.
we can give you more specifics as the time gets nearer and you actually choose a motor
Obd2 Car Obd1 Engine & Wiring SpeX ECU's, Electronics, and Tuning 16 01-10-2009 09:58 PM
OBD2 or OBD1? acolvard HYBRID -> BA-BB /CA-CD 4 12-22-2003 06:07 AM
OBD2 or OBD1? acolvard ECU's, Electronics, and Tuning 2 12-10-2003 05:17 PM
obd2 motor into obd1 hatch hatcher HYBRID -> EG-EK / DC 19 11-05-2003 12:13 PM
can you SEE a difference between a obd1 and obd2? 89honda90 ECU's, Electronics, and Tuning 6 08-13-2003 12:37 AM
