Whats a Good Cam to run with No2?
Closed Thread
Old 10-03-2003, 02:54 PM   #1
Ninja Member
Cashizslick's Avatar
Cashizslick has a reputation beyond repute
Cashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond reputeCashizslick has a reputation beyond repute
Hey all, what are some good cams to run with n2o? I hear that Toda Spec B's are real good cams for (streat/track), but since they are designed for NA use, they have a long Duration in addition to a High lift - is this bad since i am gonna be running n2o? I dont wanna over pressurize anything, so maybe i should get a cam with a High lift/short Duration?
What do you think - thanks a lot
BTW - please suggest some cams that would work well with n2o
Cashizslick is offline
Old 10-03-2003, 03:04 PM   #2
NoJokE is off the scale
Send a message via AIM to NoJokE
Its n2o and you dont HAVE to change your cams to run a 50 or even a 75 shot.
NoJokE is offline
Old 10-03-2003, 03:08 PM   #3
Ninja Member
(typo)
i want to change my cams, cause it is stupid to run n2o on a completely stock motor - if i did that, i'd be pissed off whenever i wasnt runnin it cause my car really wasnt any faster at all.
I want to change the cams cause i WANT to change them (you know, to make more power when im not on the squeeeze)
Old 10-03-2003, 03:19 PM   #4
Ride:  nothing
khrisb is a jewel in the roughkhrisb is a jewel in the roughkhrisb is a jewel in the rough
Send a message via AIM to khrisb myspace
They make cams specifically for nitrous. Look around.
khrisb is offline
Old 10-03-2003, 03:24 PM   #5
Im pretty sure those cams would be in cases where a 100+ shot of Nitrous will be used, and that wont be safe to run that high a shot without getting into the bottomend.
NoJokE is offline
Old 10-03-2003, 04:44 PM   #6
Ninja Member
Well, i dont plan to run any more than a 75 shot (eventually) so, i guess ill be ok with the TODA Spec B's.
if im wrong, tell me.
Old 10-03-2003, 04:47 PM   #7
JDMilan is off the scale
I belive it's NO2, one nitrogen and two oxygen,,,just for records..
just make sure your internals can handle the extra heat and hp..
JDMilan is offline
Old 10-03-2003, 05:28 PM   #8
Ninja Member
So, the cams should work fine then? I want to get the TODA's cause they would give me great hp/tq gains - i was just concerned about the duration being a proplem (i know it is for turbo applications).
Old 10-04-2003, 01:31 AM   #9
its definitely n2o Milan
NoJokE is offline
Old 10-04-2003, 01:41 AM   #10
Ride:  nothing
WHOA!!! This isn't me. At this time this morning, I was at Bayou Bills, drunk off my ass. I think I need to take off my auto login feature.
khrisb is offline
Old 10-04-2003, 01:50 AM   #11
Stick to postwhoring... DUMBASS! its n2o, if it was 2 parts oxygen it would be DIoxide, DI meaning 2... finish fucking highschool THEN maybe you can talk shit.
N
O
NoJokE is offline
Old 10-04-2003, 02:16 AM   #12
Ride:  nothing
khrisb is offline
Old 10-05-2003, 07:02 PM   #13
racecarl is off the scale
Send a message via AIM to racecarl
What kind of nitrous are you running? Well... I guess that doesn't matter so much, but ZEX teamed up with Crane cams (correct me if I'm wrong) and made some nitrous specific cam setups that I've heard really good things about. Check them out at www.zex.com or at the crane homepage, which i don't know.
if you get it done, POST YOUR RESULTS.
racecarl is offline
Old 10-07-2003, 03:24 PM   #14
Ninja Member
thanks, np
Old 10-08-2003, 10:30 AM   #15
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
Comp Cams, not Crane.
Calesta is offline
Old 10-08-2003, 10:34 AM   #16
Ride:  '92 Civic CX
D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
yea its comp not crane and they are nice as shit.
D See 2 is offline
Old 10-31-2003, 05:05 AM   #17
japspec99 is off the scale
if you use the toda spec B cams you will need the following before you even think about getting n20... toda b-series cam gears, toda valve springs, toda high power timing belt, and for the spec B cams you need to get head work done such as port and polish and a 3-angle valve job. that set up should net 25 whp gains or more depending on the mods you already have.
japspec99 is offline
Old 10-31-2003, 05:28 AM   #18
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
Bringing dead threads back for the sake of adding zero value comments is a bad thing. Please refrain from doing so in the future.
Thread locked to prevent further post whoring.
pissedoffsol is offline
Closed Thread
how gay is good charlotte? AVENGED Members' Lounge 17 07-31-2003 01:12 AM
Good Tires SolPWR Wheels / Suspension / Tires / Brakes 23 07-14-2003 01:21 PM
Good Trade? b18b1 ECU's, Electronics, and Tuning 9 05-21-2003 09:54 AM
What Is A Good Motor. robdup2002 HYBRID -> EG-EK / DC 2 04-07-2003 03:28 PM
is this a good deal on wheels? sportlinecrx Wheels / Suspension / Tires / Brakes 26 10-02-2002 12:16 PM
