will a bad valve make the engine idle irratic?
Old 09-27-2004, 10:36 AM   #1
Rep Power: 13 The WORLD is yours... is off the scale
i have no clue if it does or not. just shooting in the dark here!!
but, i got to thinking about it. and someone had said to me something like "if a valve isn't sitting/sealing right" then it'll let something in the block!! i don't remember if he had said air? or oil? or both?
does this make any sense to you guys?
cuz it doesn't to me!!
thanks
The WORLD is yours... is offline   Reply With Quote
Old 09-28-2004, 12:01 AM   #2
Rep Power: 18 CRseX84 is off the scale
Send a message via AIM to CRseX84 Send a message via MSN to CRseX84 Send a message via Yahoo to CRseX84
my buddy had a burnt valve and it jsut made his truck run reallll freaky. like jsut not right. if you hook up a vacume gauge on it. it wil fluctuate dramaticly... same will happen if you have a hole in ur valve... you just loose all your combustion in that cyl. but i havnt heard that it wil hurt ur botom end if thats what ur asking... i could be wrong tho.
CRseX84 is offline   Reply With Quote
Old 09-28-2004, 02:21 AM   #3
Rep Power: 14 Arachnid is off the scale
first off what happened to your car for you to assume a bent valve? did your car just started not running right for no apperent reason?
Arachnid is offline   Reply With Quote
Old 10-06-2004, 07:36 PM   #4
Rep Power: 12 shithatch is off the scale
Send a message via MSN to shithatch
Do a compression check. I just roasted a valve in my d15 and it made it basically sound like it was mis firing. Or running on 3 cylinders. The ecu was popping out a fuel injector code 16. I checked everything and did a compression check. No compression at all in the first cylinder=bad valve. It also idled erratic right b4 it totally went bad.
shithatch is offline   Reply With Quote
Old 10-06-2004, 07:53 PM   #5
swanny's Avatar
Rep Power: 51 swanny is on a distinguished road
Send a message via AIM to swanny
erratic idle meaning....? Is it a hi-low idle where it rev's to 3 grand and back down again?
swanny is offline   Reply With Quote
Old 10-06-2004, 08:12 PM   #6
at idle... mine ran from about 1-2000 rpm im guessin thats wat hes having if the valve is bad. Check your compression!!!!
