Go Back   HondaSwap Forums > Model Specific > Fit and Jazz
1.4se cvt-7 Jazz service
Old 08-30-2006, 03:57 PM   #1
Rep Power: 7 rogbrown is on a distinguished road
Default 1.4se cvt-7 Jazz service
Hi our JAZZ needs a service,that includes checking the valve clearance, local main dealer quoted 362 uk pounds 517 euros!!!. So I've decided to find out how to do it myself, but need the inlet/exhust clearance specs, can anyone help please..tks
rogbrown is offline   Reply With Quote
Old 08-30-2006, 07:47 PM   #2
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
They should be listed on a sticker under the hood... at least that's how it is in the US. It should also be in your owner's manual.
Old 08-31-2006, 11:39 AM   #3
Default valve clearance
Hi again, really wish that Honda had put more information on the sticker under the bonnet (hood), only says about the coolent and aircon, nowt else.
So if anyone knows the camshaft valve clearance for inlet & exhust it would be very appreciated.
Old 09-03-2006, 06:11 PM   #4
Ride:  93 del Sol Gas sipper
Rep Power: 101 asmallsol is a jewel in the roughasmallsol is a jewel in the roughasmallsol is a jewel in the rough
Here in the states we don't even have that engine size although I would imangine they are similar. I would invest in a service manual for your engine. You should be able to pick one up at the dealer.
Collin
Material Science and Engineering
Michigan Technological University
Old 09-18-2006, 08:15 PM   #5
Ride:  i have 14 cars i drive my sohc turbo ef
Rep Power: 34 97hatch is a jewel in the rough97hatch is a jewel in the rough97hatch is a jewel in the rough
how many miles are on the thing is it making noise? Ive seen motors with 200k+ and they were still tighter than the manual list
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS.
97hatch is online now   Reply With Quote
Old 09-20-2006, 08:50 AM   #6
I agree the valve clearances may be fine, but, until I can check I dont know,
Honda actually carry out this check every 25,000mls and I presume they know what they are doing, cant see them checking unless needed.
What I need is the spec for the gap, anyone help?
Old 09-20-2006, 10:27 PM   #7
unless it is making lots of noise i woildnt worry about it
Old 09-21-2006, 01:36 PM   #8
What if the gaps are closing up due to crap un-leaded petrol, erroding the valve seats, it will be quiet then !!
Old 09-21-2006, 06:34 PM   #9
lol i guess that could be a problem but you will have other problem b4 this happens i dont know about the specs i was just trying to give you some peace about the situtation
Old 10-06-2006, 06:30 AM   #10
Smile Valve Clearances
Well after a lot of research, result!!
Jazz 1.4 L13A 8V SOHC i-DSI engine 2002-2006
Inlet valve 0.15 to 0.19mm (6-7 thou)
Exhust valve 0.26 to 0.30mm (10-12 thou)
Rog...
Old 10-17-2006, 10:21 AM   #11
Rep Power: 0 angusgillespie is on a distinguished road
Well done! That was my exact question - about the valve clearances. Our dealer has not renewed the spark plugs in 35000m and now the car is going like a bomb after installing new spark plugs in half an hour. Great saving, as the dealer quoted us £140.00 for the job. I am betting that they have not checked the valve clearances...
Many Thanks
angusgillespie is offline   Reply With Quote
Old 10-19-2006, 03:50 PM   #12
Default Spark Plug change
Glad that you saved yourself a fortune over main dealer prices, and that you cars running better.
Did you lash out for "IRIDIUM" spark plugs (last 70,000mls + ) or just stuffed in the standard ones?
Old 10-20-2006, 05:16 AM   #13
No - Just the standard NGK Honda supplied. They seem OK. Next it will be front brakes, I guess. Honda only publish workshop manuals on much older models. Neat ploy to keep the punters coming back.
Old 10-21-2006, 05:25 AM   #14
Default Workshop manual
I bought a CD that was advertised on e bay for a mear £4.99 ( $8.98)
really good, well worth the money, dont doubt that Hondas one would cost a fortune.
Rog....
Old 12-19-2006, 08:21 PM   #15
Rep Power: 0 evolusia is on a distinguished road
Default 1.4 jazz valve adjustment
Hi guy`s, I need to check the valve clearance on my Jazz as well. My local dealear says that a valve compressor tool is required to do the job. Does anyone know the cam set up on these engines or how to do the adjustment. I suspect that there may be shims in the set up if a tool is required.
evolusia is offline   Reply With Quote
Old 12-20-2006, 05:01 PM   #16
Looks like its only a spanner/screwdriver and a set of feeler gauges setup!!
Old 12-20-2006, 06:48 PM   #17
Default Jazz valve clearance
Thanks for the quick reply, much appreciated. Looks like my LHD was bigging the job up for the £370 service charge.
Old 12-21-2006, 08:52 AM   #18
Now I wonder why they would do that!!
As for needing a spring compressor tool, looks like even their V-Tech engine has the same adjusting arrangements... Rog.
Old 04-02-2007, 07:17 AM   #19
Found this, explains all !!!!!
rog....
Valve Clearance Adjustment (L12A/L13A)
Old 04-03-2007, 03:19 AM   #20
Calesta's Avatar
Ride:  2003 S2000
Old 04-03-2007, 04:51 AM   #21
Calesta, glad to be of service. Hopefully, others will pick up
the information, it's an relatively easy job to do, just time
consuming. Which is the reason the Honda garage charge so much.
rog....
Old 04-04-2007, 08:15 PM   #22
*princess*
Black Widow g2's Avatar
Ride:  90 Integra B16 turbo, 00 Civic Si B18C n/a, 07 Fit Sport
Rep Power: 71 Black Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud ofBlack Widow g2 has much to be proud of
Send a message via ICQ to Black Widow g2 Send a message via AIM to Black Widow g2 Send a message via MSN to Black Widow g2 Send a message via Yahoo to Black Widow g2 myspace
I was looking at the i-DSI engines... interesting how they use it...
~ArtieTuned - EFI University Certified Tuner~
*ECU Chipping*Custom Programs*Street/Dyno Tuning*
Crome Pro*Motec*Haltech*Autronic*Hondata* Uberdata*Neptune*Fast*AEM* MegaSquirt*and more
In the NorCal area
http://www.artietuned.com
e-mail: tuner@sonic.net or PM me
Black Widow's Baby Pool
Black Widow g2 is offline   Reply With Quote
Old 04-26-2007, 04:00 AM   #23
Rep Power: 0 wil4rdus is on a distinguished road
i was wondering.. is l13a idsi automatic timing?? i cant find the distributor
wil4rdus is offline   Reply With Quote
Old 04-26-2007, 06:52 PM   #24
Dismember
Ride:  Whatever i can get behind the wheel of
Rep Power: 263 klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
klyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond reputeklyph has a reputation beyond repute
I don't think it has one, It's coil on plug if I'm not mistaken.
Go to work, Act normal, Believe the News, Save for your old age, Obey the Law
Repeat after Me: I am Free
klyph is offline   Reply With Quote
**1988 Honda Accord Factory Service Manual - Helm** nonbox Parts: For Sale/Trade/Wanted 1 07-21-2006 09:03 AM
Automotive technician DravenVX Members' Lounge 18 01-20-2006 10:35 AM
Demoted, Resigned in Protest, Fired etc reckedracing Members' Lounge 11 10-21-2005 10:25 AM
**1988 Honda Accord Factory Service Manual - Helm** nonbox Parts: For Sale/Trade/Wanted 0 10-15-2005 10:04 PM
