Go Back   HondaSwap Forums > Model Specific > Fit and Jazz
Mugen Sport Suspension
Old 09-06-2009, 06:20 PM   #1
Reverend Awptickes
awptickes's Avatar
Ride:  1999 Civic EJ9, 2009 Fit GE8, 2006 Suzuki SV650s
Rep Power: 184 awptickes has a reputation beyond repute
awptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond reputeawptickes has a reputation beyond repute
 FaceBook
Default Mugen Sport Suspension
The GD3 Mugen Sport Suspension will fit on the USDM GE8 fit.
There is no hole-drilling required, as the USDM GE8 uses 14mm bolts from the strut housing to the suspension uprights. Aside from the mounting points for the brake line, and the ABS cable, it's a perfect fit.
The strut housing doesn't have the mounting brackets for the ABS and brake line, so you'll have to fabricate something. I used two zipties, one around the strut housing, and one to hold the brake line to the zip tie around the strut housing.
I'll fabricate something more permanent a bit later.
Handling is as expected for Mugen's suspension package.
☻/ DIY/Howto HID Projector retrofit
awptickes is online now   Reply With Quote
Old 09-06-2009, 06:53 PM   #2
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
Awesome!
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 09-13-2009, 11:10 PM   #3
Reverend Awptickes
awptickes's Avatar
 FaceBook
The brake line brackets needed for this are:
46428-SLN-A00
46429-SLN-A00
Old 10-07-2009, 09:09 PM   #4
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
any updates? pics?
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-07-2009, 09:44 PM   #5
Reverend Awptickes
awptickes's Avatar
 FaceBook
Mugen GE8 Base
Rear
Front
Stock GE8 Sport
Rear
Front
More here:
Suspension - a set on Flickr
Zip ties have since been corrected with the proper bracket.
Front Left
Different angle
Now I just have to jack it up with one of the front side jack points. <3
Front:
Rear:
That'll make wheel changes a lot faster.
Shots showing wheel gap and ride height:
Front wheel gap:
Rear wheel gap:
And my mother's BMW to compare rear wheel gap:
More here:
I'll have some more pictures with the new brackets tomorrow when I swap on the winter tires/wheels.
The only extra parts you need besides the GD3 Mugen Suspension:
GD3 Brake line brackets
GD3 Brake lines
GD3 End Links (not really needed, but helps maintain the suspension geometry)
Another update:
The suspension has been performing flawlessly. The ride height isn't bad at all, I don't have to worry about speedbumps or anything. I took the fit to Ocean City, and drove on some really bad roads, I scraped the airdam getting to a gas-station, but nothing else. And I don't drive especially carefully.
I have put about 2k miles on the suspension now, and I have loved every bit of it. The car responds, it hasn't almost gotten out from under me, and I feel in-control. I dn't feel like I'm driving an econobox, just an underpowered car that understeers.
I still need to fix the understeer problem, at the Philly airport Sunday I noticed how bad it understeers. I'm going to try playing with tire pressures a bit again. My track pressures seem to be correct, I just have to get the street pressures fixed.
Old 10-07-2009, 09:53 PM   #6
Running on two cylinders
TurboMirage's Avatar
Ride:  2000 Mitsubishi Lancer RPW E5 Coupe
Rep Power: 338 TurboMirage has a reputation beyond repute
TurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond reputeTurboMirage has a reputation beyond repute
Send a message via AIM to TurboMirage Send a message via MSN to TurboMirage Send a message via Yahoo to TurboMirage myspace
noice.
Home of the RPW built 2000 Lancer CC Coupe.
See what is done to the little Evo5.
"If you don't like what I've done with my car, I will gladly refund all the money you put into it."
Old 10-07-2009, 10:50 PM   #7
99sidude's Avatar
Sweet! The Fit is such a capable chassis. You should look into a rear sway bar to counter the understeer. I'm surprised that it even has the problem. All of my Civics tend to oversteer when I lift off the throttle in a sharp turn.
93' dx hatch
s300 440cc RC's
Old 10-08-2009, 08:12 AM   #8
Reverend Awptickes
awptickes's Avatar
 FaceBook
Rear anti-roll bars just reduce traction in the rear, I want all the traction I can get. I'm going to play with the front roll bar before I mess with the rear. The rear is a torsion beam, so I'd rather play with the front setup first.
2x mugen sport wing badge jdm civic accord ek3 black RSS-Bot Auctions 0 05-06-2009 09:36 AM
2x mugen sport wing badge jdm civic accord ek3 black RSS-Bot Auctions 0 04-29-2009 10:03 AM
2x mugen sport wing badge jdm civic accord ek3 black RSS-Bot Auctions 0 04-08-2009 09:36 AM
K Sport Suspension Full Coil Over Integra Civic Dc Eg RSS-Bot Auctions 0 02-01-2008 11:53 PM
FS:FT: DA MUGEN SPORT SUSPENSION racerxb20z Parts: For Sale/Trade/Wanted 5 07-14-2004 08:56 PM
