Air/fuel Meter Vs Egt Meter
Old 06-13-2003, 05:36 PM   #1
Rep Power: 14 JDMSpecAccordSir-T is off the scale
I have an arguement going with some of my friends. They say if you have a EGT meter then you don't neccesarily need a A/F meter. I say the A/F meter is more accurate. What do you guys say?
JDMSpecAccordSir-T is offline   Reply With Quote
Old 06-13-2003, 10:55 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
a/f gauge is 99% worthless without a wideband o2 sensor.
EGT is a must in my opinion
Old 06-15-2003, 01:24 AM   #3
Thats the first time ive heard of a wide band 02 sensor. What is it exactly (im thinking 2 bar map sensor )?
With it, would the A/F meter be better than a EGT meter (tuning wise)?
And I dont mean to rant on you (rather im going to make a point) but would please explain why you have come to that conclusion rather than just stating your opinion because most people (and me) prefer facts over opinions. This seems to have become the norm around here nowadays ( I've seen quite a few people complain about that).
To think, I thought this was supposed to be a place where I actually learned something .
JK
Old 06-18-2003, 12:07 PM   #4
Rep Power: 14 hondaguy72 is off the scale
To answer the question, a wideband O2 is different than the factory O2 sensor in that it can read voltages which span the entire range of rich to lean. The factory or aftermarket type O2 sensors can only send a very narrow band of voltages to the meter. On the other hand, a temp sensor (EGT) can read all temperatures. The only problem with an egt sensor is that you need to interpret the data. High exhaust temps could be caused by either a lean condition, or fuel igniting in the exhaust path. The ideal tuning tool IMO is a wideband lambda meter (O2).
hondaguy72 is offline   Reply With Quote
Old 06-18-2003, 08:51 PM   #5
Rep Power: 29 knowledge is off the scale
http://www.ks-motorsports.com/index.php?pa...33e9b32f7f93651
The C5 is strong with this one........
knowledge is offline   Reply With Quote
Old 06-19-2003, 02:11 AM   #6
RETIRED
ive heard that aem shit only works well with the aem ems... nothign else.
anyway, as far as wideband- its like this
as you can see, the narrow band (or normal) o2 gets about the same reading... from rich, to stoich, to lean.... its all withing .0x voltages, and something that simply can't be read accurately with a device.
the wideband uses a wider voltage span, to show lean, stoich, and rich conditions based on a voltage- how 99% of other sensors work.
Air/fuel Gauge IDMaxGuy ECU's, Electronics, and Tuning 6 03-02-2004 10:40 PM
02 Sensor wire on Air/Fuel meter turns it off? hatchboy HYBRID -> ED-EF / DA 11 11-02-2003 05:50 PM
A/F ratio meter rudeludenotmeanthough General Tech and Maintenance 15 09-15-2003 08:07 PM
Air/fuel Guage Drenni General Tech and Maintenance 11 04-07-2003 08:39 PM
Air/fuel Ratio liquid00meth General Tech and Maintenance 3 02-25-2003 07:58 PM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
