Facebook Twitter
B16 Home-made Turbo
This is a discussion on B16 Home-made Turbo in the Forced Induction forum
Ok, I have a 2000 civic SI. I was wondering of putting a turbo in there, but I saw the kits and they are very expensive. So I thought maybe I can make my own. I can learn very quickly where stuff goes and everything, ...
Old 03-20-2003, 10:15 PM   #1
Thumbs down
Ok, I have a 2000 civic SI. I was wondering of putting a turbo in there, but I saw the kits and they are very expensive. So I thought maybe I can make my own. I can learn very quickly where stuff goes and everything, but I dunno what stuff to use!!! In other words, can anybody please explain to me what type of turbo I can put into my SI? Has anyone here put a turbo into an SI? Please help!!
Tirado8014 is offline   Reply With Quote
Old 03-20-2003, 10:16 PM   #2
J
J's Avatar
www.homemadeturbo.com 0wns j00!
J is offline   Reply With Quote
Old 03-21-2003, 01:04 AM   #3
Red face
Basic:
Feul mangement
Turbo
Manifold
BOV
Intercooler
Piping
That's the basic
Feul mangement can be: A hondata ecu, FMU, vafc-hack you name it
CALVIN
calvin is offline   Reply With Quote
Old 03-21-2003, 07:04 AM   #4
add wastegate, boost control and downpipe to list above.
great, inexpersive fuel managemnet setup is a v/s-afc (the hack sucks, just wire it up like the instructions say and put some check valves on so your ecu doesnt see boost) and some dsm 450cc injectors. You can proly get those two for about 250-350 on dsmtrader.com.
A t3/t4 seems to be the way to go for the turbo on a b16 but you could always source another used turbo off the millions of turbo cars out there if youre going mad cheap.
DONT RUN TOO MUCH BOOST OR TIMING ADVANCE!!!
good luck
B16 + '89 CRX Hf
<a href=\'http://b16a.honda-perf.org/tech.html\' target=\'_blank\'>http://b16a.honda-perf.org/tech.html</a>
^--most everything you need to know
<a href=\'http://hasport.com/Tech/Hasport%20Tech.htm\' target=\'_blank\'>http://hasport.com/Tech/Hasport%20Tech.htm</a>
^--and anything the first may have missed
heterosapian is offline   Reply With Quote
Old 03-21-2003, 08:53 AM   #5
for the hack, could I use an s-afc? And should I get the newest it can be adjustd in Adjustable fuel increments of 200 rpm .
Ractive78 is offline   Reply With Quote
Old 03-24-2003, 08:38 AM   #6
don't worry about the boost controler and wastegate, cause chances are if you are building a cheap kit (i.e. junkyard kit) your proly going to have an internal wastegate already, and with that you aren't goin to need the controler unless your building your internals so they can handle the build up
hybridsol is offline   Reply With Quote
Old 03-24-2003, 08:42 AM   #7
pissedoffsol's Avatar
Originally posted by Ractive78@Mar 21 2003, 09:58 AM
[b] for the hack, could I use an s-afc? And should I get the newest it can be adjustd in Adjustable fuel increments of 200 rpm .
safc doesn't have VTEC control, other than that, it IS a vafc.
Old 03-24-2003, 01:16 PM   #8
Originally posted by heterosapian@Mar 21 2003, 08:09 AM
[b]
ehhh- i dont see how the afc is gonna let you run 450cc injectors unless you cut the fuel percentage way down, in that case it would BE the afc hack- tricking the ecu into thinking its in vaccuum, advancing the timing
SolReaver is offline   Reply With Quote
Old 03-27-2003, 12:34 PM   #9
on homemadeturbo.com the problem with building your own turbo they say is you can't keep your a/c (well from the cars they spooled anyways)so if you care about being cool don't do it (unless you live in alaska or something) buy a kit and if no one makes one retrofit it
whatdahieu is offline   Reply With Quote
Old 04-02-2003, 12:44 AM   #10
u can keep ur a/c, but u would have to get a turbo manifold that would let u keep ur a/c..
Civic_88ls is offline   Reply With Quote
Old 04-02-2003, 12:24 PM   #11
How does it even interfere with the AC. The compressor is on the opposite side of the manifold as the turbo?
liquid00meth is offline   Reply With Quote
Old 04-02-2003, 06:12 PM   #12
On homemadeturbo.com, they put the turbo on the driver's side of the manifold, which is different than most after-maker manifolds and turbo kits. They did this because it is easier to run the charge-pipes on the driver's side and remove the a/c. It can be done either way tho.
RFHOMI2U is offline   Reply With Quote
home made turbo kit ^crx^ Forced Induction 20 08-08-2004 09:21 PM
HOME MADE PORT & POLISH arpee79 General Tech and Maintenance 12 01-22-2004 12:46 AM
difference between turbo sizes SnailOnARampage Forced Induction 4 11-12-2002 03:53 PM
which turbo on a b16 crxracing77 Forced Induction 20 10-19-2002 07:16 AM
© 2001-2013 HondaSwap.com
