B18b Turbo t3/t4 or t25 , t28
Old 01-26-2004, 12:13 PM   #1
Rep Power: 0 CYULOST1 is off the scale
I want to turbocharge my B18b at 6-8psi and i want to know what's the best setup to run like that: more lag with t3/t4 than a T25 or T28 ??
CYULOST1 is offline   Reply With Quote
Old 01-27-2004, 03:24 AM   #2
Rep Power: 14 highlife is off the scale
i said go with greddy TD05 18G, its a cleaner turbo kit and everything is there so u dont have to mess with missing parts and stuff
highlife is offline   Reply With Quote
Old 01-27-2004, 06:50 AM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
well, how about setting a goal for power first. what do you want to hit?
6-8 psi is not a goal. its a pressure level. Stop reading bullshit on the net at stupidhonda.com =) welcome to hondaswap, where we actually know what we're talking about (most the time hehe)
6 psi off a dinky t25 will net you 30-40 hp
6 psi of a t3/t04e will probably bump ya 75-80
so, as you can see- 6 psi is still 6 psi, but your bump in power has almost doubled.
how is a greddy kit "cleaner"? Their manifold sucks. it has all the same other parts as every other kit, and it comes with a blue box
Old 02-14-2004, 08:55 PM   #4
What about lag ??
Old 02-14-2004, 09:42 PM   #5
Rep Power: 35 NotUrAverage_Si is off the scale
depends, my set up is a t3/t04E, 60 trim compressor housing, .82 A/R turbine housing.
my turbo doesn't spool up until after VTEC engages. I don't really mind the turbo lag cause once the turbo does spool up I'm out like a fat kid at dodge ball.
of course you'll have less lag with a smaller turbo, but in the long run you'll make more power with a t3/t4.
'00 <span style=\"color:black\">FBP</span> Civic <span style=\"color:red\">Si</span>-T
|<a href=\"http://www.full-race.com\" target=\"_blank\">full-race</a>|<a href=\"http://www.goldeneaglemfg.com\" target=\"_blank\">golden eagle</a>|<a href=\"http://www.fast-turbo.com\" target=\"_blank\">fast-turbo</a>|<a href=\"http://www.hondata.com\" target=\"_blank\">hondata</a>|<a href=\"http://www.wiredspeed.com\" target=\"_blank\">wiredspeedlab</a>|
email: boostfedEM1@yahoo.com
<div class=\'quotetop\'>QUOTE(dohch22a4 @ Sep 20 2004, 11:44 AM)</div><div class=\'quotemain\'> Please, Obi Wan B, you're our only hope.
</div>
<span style=\"font-size:36pt;line-height:100%\"> <a href=\"http://www.nissantech.com\" target=\"_blank\">www.NissanTech.co m</a></span>
NotUrAverage_Si is offline   Reply With Quote
Old 02-14-2004, 11:20 PM   #6
RETIRED
Originally posted by CYULOST1@Feb 14 2004, 08:55 PM
What about lag ??
Lag, for the most part, happens in 1st gear only when you are racing. lag is also a good thing for a street car- out of boost, you're using a LOT less fuel, and thus you get better mileage, all the while having a larger power gain.
.82 is huge. most 600whp hondas don't use that big of a wheel. mine is .70, most are .63, smaller ones are usually .48. anything less, why did you bother
Old 02-15-2004, 12:56 AM   #7
I got it for $80, how could I resist?
I got BIG plans for my little civic. not exactly 600whp kind of plans, but I'll be happy with 350whp, which is what the gsr hatch the turbo came off of put down.
</div>
Old 02-19-2004, 06:47 PM   #8
Rep Power: 20 SolLess16 is off the scale
Send a message via AIM to SolLess16
damn ya cant beat that , run a T3T4 with a .48
93 Del Sol - D16Z6 Turbo
SolLess16 is offline   Reply With Quote
Old 10-16-2005, 05:41 AM   #9
Rep Power: 0 kiler goose is off the scale
will the t3/t4 fit in a eh2 bay wit a b18c1 ??
kiler goose is offline   Reply With Quote
Old 10-16-2005, 08:12 AM   #10
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
Rep Power: 122 92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
yes...
I had a 42/48 on my LS, first, it made acceptable power, but you'll crave more. I think it was around 200 or so to the wheels. I was having problems so I found a decent 60/63 and a cheap rebuild kit. Since my DP and everything was already setup for the 42/48 I just swapped the compressor housings and rebuilt/modified it to a 60/48. I loved that turbo. Spooled very quickly and made good HP.
I would personally go with a 60/63, good all around power and it should be at full boost by 3-4k.
Fuck ther TD series turbos, go with a t3/t4
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 10-20-2005, 08:35 PM   #11
Rep Power: 15 DelSlo is off the scale
woohoo my first ebay bid!!
im tempted to try this .42/.48 t3 garrett/airsearch, its not a bad deal, but i dont know if i should hold out till a decent priced 0.63, 0.60. im shooting for 250-300hp on a b16
im not tryin to thread jack, just figured id join in instead of starting a whole new thread with the same questions!
93' Del Sol
2000 B16A2 swap.
garrett T3/T4 (.48/.60)
Weapons of choice.. Innovate LC1 and Crome Pro
Faze EL Engine management guages.
DelSlo is offline   Reply With Quote
Old 10-22-2005, 01:58 AM   #12
Rep Power: 14 hotrex is off the scale
delslo, you will not make any good hp with a 42/48 on a b series.
it will run out of its efficiency range way before redline. it will fallflat on its face and starve your motor.
b16a has a high volumetric efficiency the head flows alot of cfm, and that turbo does not.
at the very minmum id run a t3 60/63 nothing smaller, but def somethuing larger.
t3/t4 57 trim is ideal for your goals
www.cc-fab.net
for all your turbo manifold and charge piping needs,
hotrex is offline   Reply With Quote
B18B with Greddy Turbo... Circuit Engine Building 3 10-22-2003 07:16 PM
Is there a Supercharger kit chap_e77 Forced Induction 3 08-26-2003 07:09 PM
Gt4 Y0! pissedoffsol Members' Lounge 33 06-18-2003 01:13 PM
B18b For Turbo pjecthatch Engine Building 2 03-07-2003 04:10 AM
Nitrouse And Turbo On B18b orangecivic Engine Building 5 01-21-2003 01:07 AM
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
