Facebook Twitter
ball bearing turbo,what size oil restrictor?
This is a discussion on ball bearing turbo,what size oil restrictor? in the Forced Induction forum
my friend is going to be running a normal t3/t4 turbo and doesnt want to blow the seals..so ive been checking around and ive HEARD that we should run a .035 oil restrictor with a ball bearing turbo...now ive searched and can not find this ...
Old 02-22-2011, 11:35 AM   #1
INJEN78's Avatar
Default ball bearing turbo,what size oil restrictor?
my friend is going to be running a normal t3/t4 turbo and doesnt want to blow the seals..so ive been checking around and ive HEARD that we should run a .035 oil restrictor with a ball bearing turbo...now ive searched and can not find this size restrictor..all i can find is .065 which ive heard is best for journal bearing turbo's because they require much more oil pressure for longevity...so what im wondering is
1.WHAT SIZE OIL RESTRICTOR DO WE USE ON t3/t4 BALL BEARING TURBO
2.WHERE CAN I FIND OIL RESTRICTOR KITS
R.I.P BEN LEE2/24/08 we love and miss you
WWW.CTDRAG.COM
GOOD FAST CHEAP,
you can pick only two.
fast and cheap isn't good
good and cheap isn't fast
good and fast isn't cheap
INJEN78 is online now   Reply With Quote
Old 02-22-2011, 12:33 PM   #2
B
B's Avatar
you don't need a restictor if you run the right (-3an) size feed line.
B is online now   Reply With Quote
Old 02-22-2011, 12:36 PM   #3
TurboMirage's Avatar
was just about to say that
and if you need them you can get them on ebay. you dont want more than 35psi pressure running through the turbo. 1/16th should be ok and if too small you can always drill it out to 1/8th.
TurboMirage is online now   Reply With Quote
Old 02-22-2011, 03:24 PM   #4
INJEN78's Avatar
well idk what 3/8 oil line converts to -an wise but i do know that its got an 1/8npt fitting on the end for running an 1/8npt fitting.
Old 02-22-2011, 03:55 PM   #5
B
B's Avatar
AN is base 16, therefore, 3/16". 3/8 is twice too big as you should be running.
AN and NPT fittings
Old 02-22-2011, 04:13 PM   #6
INJEN78's Avatar
fuck so i guess im running a -6an hose..im def gonna get a restrictor then.
Old 02-22-2011, 04:15 PM   #7
INJEN78's Avatar
so im going to look around for a .035 restrictor..the only thing is ebay does not offer one that size,
Old 02-22-2011, 04:29 PM   #8
INJEN78's Avatar
so is 1/8npt cross referanced to -4an??
Old 02-22-2011, 06:36 PM   #9
B
B's Avatar
just replace "an" with "/16" and you get your size, ie 4/16" or 1/4"
Old 02-23-2011, 09:17 AM   #10
INJEN78's Avatar
so wtf do i get for an -an fitting??
Old 02-23-2011, 05:17 PM   #11
INJEN78's Avatar
can anyone help?? im new to this -an and npt bullshit...i was just told by some company that 1/8npt converts to -2an?!?!?!
but i just looked in speedway motors magazine where they have size charts and 1/8npt is showing to be -4an...
Old 02-23-2011, 06:49 PM   #12
B
B's Avatar
they will almost never match.
NPT is a fitting based on inside diameter of item it (most of the time) screws in to
AN is fitting as measured on outside diameter of the hose it (most of the time) clamps on to
AN Fitting Thread Size Chart
so,
think of NPT as the fitting that goes IN the hose and AN as the fitting that clamps on the outside of the hose.
AN's are almost always used on the hose itself, where as the npt fitting goes into he block, or other 'tapped' item
thickness of the hose itself will vary, thus an -6an hose may require any number of different fitting ends, depending on the hose thickness.
At the end of the day, you can't build a feed/return line yourself cheaper than you can just to buy one, so, just buy one.
Fast-Turbo Complete Turbo Oil Line Kit
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
Old 02-23-2011, 08:45 PM   #13
INJEN78's Avatar
this is the feed line kit that my friend is getting-
37' 'TURBO OIL FEED LINE KIT 240SX KA24DET CA18DET S13 - eBay (item 270638408654 end time Mar-20-11 12:26:44 PDT)
...the female end fits the 1/8npt silver fitting...
but he needs to run an oil restrictor because the line is too big(-6an)
this is the oil restrictor which says its 1/8npt or -4an
Oil feed Inlet Fitting -4 Build-in restrictor GT28/30/3 - eBay (item 370485308278 end time Feb-23-11 20:16:31 PST)
all i need is for the oil restrictor to thread into the female end of the feed line..
which is why im trying to figure out if 1/8npt really is -4an or if its something else?
WWW.CTDRAG.COM
GOOD FAST CHEAP,
Old 02-23-2011, 09:05 PM   #14
B
B's Avatar
As I tried to point out above, they don't directly correlate.
Take this image.
the white inside is the hose 'flow' hole. an NPT fitting would screw INTO this area, if it were threaded.
If the black is the thickness of the hose, yellow is the AN size needed.
But if blue is the hose thickness, the brown is the AN size needed
ignore the red line, i forgot to fill that in :X but was meant to be a 3rd example of the same thing if it was filled out to that line.
maybe this will help too:
AN vs. NPT*|*Aeromotive
If the turbo is a real GT series, or clone, you can try this:
GT Ball Bearing Restrictor
Old 02-23-2011, 10:51 PM   #15
INJEN78's Avatar
alright i finally get it!!! lol
so now my dilemma is i need a .035 restrictor to run with my feedline kit.
Old 02-23-2011, 10:58 PM   #16
B
B's Avatar
click the last link above!
Old 02-24-2011, 08:19 AM   #17
INJEN78's Avatar
i did..i can get that on ebay...thats what ive been asking about this entire time.
Old 02-24-2011, 12:53 PM   #18
INJEN78's Avatar
ok so heres what its come to..im trying to figure out if this
will fit the female adaptor on my feed line..
the feed line has female 1/8npt threads
but that restrictor is for i believe -3an..
Old 02-24-2011, 12:59 PM   #19
INJEN78's Avatar
unless i just get something like this(obviously i will need 1/8npt male and -3an female)
1/8" NPT Female to -3AN Straight Fitting Gauge Adapter - eBay (item 380311970928 end time Feb-26-11 17:00:15 PST)
thread the adaptor into my oil line and then thread the actual restrictor into the adaptor...
but then thats just more that could potentially leak?
Old 02-24-2011, 02:21 PM   #20
B
B's Avatar
You need to measure what you have to match it up.
Old 02-24-2011, 02:41 PM   #21
troy just go to the damn hardware store.
Old 02-24-2011, 03:21 PM   #22
INJEN78's Avatar
thats lookin like my best bet..im going to order the restrictor now..when the feedline and restrictor get here ill figure it out from there i guess.
Old 02-24-2011, 04:33 PM   #23
INJEN78's Avatar
im gonna assume this fitting holds oil pressure?
Earl's 916103 Earl's Specialty Fittings
and thanx for the link to that oil restrictor B...i ordered it a couple hours ago.
for sale ball bearing turbo tonybronx Parts: For Sale/Trade/Wanted 1 09-03-2008 11:25 AM
for sale ball bearing turbo tonybronx Parts: For Sale/Trade/Wanted 0 09-02-2008 11:40 PM
looking for a turbo ball bearing tonybronx Parts: For Sale/Trade/Wanted 0 02-18-2008 02:54 PM
Sohc Ball Bearing Turbo Kit F/s Cheap!!!!!! whos_the_master Parts: For Sale/Trade/Wanted 26 11-21-2007 01:14 AM
Ball Bearing Turbo IntegraRUS Forced Induction 3 02-08-2003 07:15 AM
© 2001-2013 HondaSwap.com
