Facebook Twitter
the best turbo info page ive seen
This is a discussion on the best turbo info page ive seen in the Forced Induction forum
http://www.beesandgoats.com/boostfaq/g2icturbo.html great write up....
Old 01-02-2004, 01:50 AM   #1
great write up.
rudeludenotmeanthough is offline   Reply With Quote
Old 01-02-2004, 02:12 AM   #2
pissedoffsol's Avatar
not bad... i don't agree with all of it though...
Old 01-02-2004, 02:27 AM   #3
K2e2vin's Avatar
i just looked at the pictures
Old 01-02-2004, 02:30 AM   #4
2000Si's Avatar
Originally posted by K2e2vin@Jan 2 2004, 03:27 AM
[b] i just looked at the pictures
at least he's honest.
2000Si is offline   Reply With Quote
Old 01-02-2004, 04:29 AM   #5
[b]Also, due to the VTEC system, cam timing on the B17 raises some issues that need attention. The valve overlap, intake and exhaust valves open at the same time, can lead to exhaust gass reversion issues. Reversion occurs during valve overlap and exhaust gasses are drawn back into the cylinder. Obviously this is not a good thing when you are forcing an already hot, pressurized intake charge into the cylinder
reversion is not caused by vtec nor cam overlap.
its caused by shitty manifold design, and improper tuning.
[b] B17, and all other VTEC motors, will put out more horsepower with less boost than a non-VTEC motor, about 14% on average.
i'd like to know how they came up with that number....
[b]The B20 motor is a direct replacement for the B18A/B. The only advantage of the B20 over the LS motor is the extra two tenths of a liter displacement This extra displacement comes at a price however. In order to achieve 2.0 liters of displacement the cylinder sleeves were bored to 84mm from 81mm. This extra 3mm of boring significantly weakens the sleeves which can lead to cracking when subjected to boost.
well, thats mostly bullshit. nice try though...
[b]A reliable LS/VTEC motor is very difficult to build, as such it should only be attempted by an engine builder experienced with building LS/VTEC motors. Since building a good LS/VTEC motor is such an art, engine builders charge a premium for their services. Also keep in mind that the bottom end of a LS motor was not designed to rev up to the level where the VTEC motors are meant to shine.
more BS...
[b]One advantage to a higher compression ratio is better low end power and response.
poor wording.. low end has nothing to do with it. its in Vacuum where the compression difference will be most noticable.
[b]Aftermarket sleeves are thicker than stock sleeves and are also designed to resist walking, moving from side to side, in the water jacket which can compromise the seal between the head and block resulting in a blown head gasket
they aren't thicker. they are jsut made of difference materials. and i've never heard of a headgasket blowing due to "sleeve walk????"
[b]Turbochargers operate on heat and exhaust gas velocity characteristics.
while heat does induce greater flow, do to thermal dynamics, a turbo does not need heat to operate.
[b]Stainless steel is used on most tabular manifolds
ohh!!!!! Tabular manifolds!!!! i want one
[b]Stainless steel retains heat better than cast iron but it is also more expensive.
says who? there's 2312 types of SS and millions of ways to cast something.
[b]One option is to have the Garrett T3 flange removed from a manifold and have a flange for the 14B/T25 welded on.
14b and t25's do not share the same flange. wtf mate?
[b]The wastegate has an internal spring which boost pushes on,
uhh, no it doesn't. wastegates operate off a vacuum system.... it sees vac/boost much like your brake booster would from the intake manifold or other vacuum source.
[b]Boost creep occurs when even though the wastegate is open, boost continuous to rise, usually as the engine approaches high RPM. This occurs because the wastegate port is to small, or is in a bad position, and enough exhaust gases cannot bypass the turbo through the wastegate, making boost levels rise. Fortunately this is a rare condition and is not often a problem unless you are making over 500 horsepower.
rare? 500 hp? most boost creep comes from shit manifolds on 250 whp cars
[b]The intercooler is required to reduce the air charge because as the air is pressurized by the turbo
how about no, scott.
[b]Obviously a larger intercooler will do a better job than a small intercooler
like your girl told you, size isn't everything. and yes, there is such a think as going too big.
[b]Getting an intercooler that is thicker compared to another model should be avoided because the ambient air flowing through the intercooler heats up the further it flows through the core, decreasing its ability to cool the air charge the further it flows through the core.
on a low horsepower setup, sure. on a high powered car, no. you need all the space/volume you can get
[b]Of course nobody has every blown up a piston running rich.
and i still don't get what he's trying to fucking say....
i dunno i got bored about half way....
just be advised taht theres a lot of wrong info or opinion in there.
Old 01-02-2004, 06:41 AM   #6
K2e2vin's Avatar
damn im glad i didnt read it.
Old 01-02-2004, 12:24 PM   #7
2000Si's Avatar
Originally posted by pissedoffsol
[b]
hahaha
Old 01-10-2004, 02:15 PM   #8
i guess they saw my post...
real mature...
pissedoffsol,
MonRex has sent you this email from http://www.hondaswap.com/forums/index.php.
You sure are good at talking shit when people can't respond back. If you have all the answers why don't you make some constructive criticism instead of the wise ass comments? I'm thinking that once you've put as much time in as it took to write that guide then you can talk shit.
Please note that HondaSwap.com has no control over the
contents of this message.
Regards,
The HondaSwap.com team. http://www.hondaswap.com/forums/index.php
pissedoffsol,
TurboGuide has sent you this email from http://www.hondaswap.com/forums/index.php.
Hey! I just wanted to let you know that I implemented some of your suggestions in my guide. Congratufuckinglations on being the one person that found tabular, you really do know your shit! Despite some of it's shortcomings, it provides far more good information than any other single source around. And I'll tell you what. After you've spent over a year of your time writing something like this, then you can talk shit. How's that sound?
Regards,
congratualtions. fuck yourself.
good bye.
Old 01-12-2004, 01:07 AM   #9
LMAO, so if it takes you a year to come up with that shit imagine what you could pull out of your ass if four. I was going to read that until I saw the quotes. Do you work on Honda's? I couldn't help but notice the complete lack of attempt to back up the info in question...
cws13 is offline   Reply With Quote
Old 01-12-2004, 01:51 AM   #10
damn I'm glab you gave an overview on most of that thing, B. I never would have gotten up enough energy to read it.
NotUrAverage_Si is offline   Reply With Quote
Old 01-12-2004, 02:37 AM   #11
don't get me wrong--- there's a lot of good info in it- but at the same time, theres a lot of stuff that just isn't true or a matter of opinion. If you're smart enough to know whats right and wrong in it, its a good resource. if you're just a beginner and aren't really sure about much, it could easily throw you into thinking the wrong stuff.
Centrifugical Supercharger Vs Turbo JDMSpecAccordSir-T Forced Induction 50 08-19-2010 02:40 PM
Anyone Have Edelbrock Performerx Turbo? mbanks21 Forced Induction 7 08-07-2006 02:57 AM
TPP's new turbo stuff BodyDroppedNikes Auto Multi-Media 9 07-14-2004 11:54 AM
Turbo Turbo Turbo dorito_burrito HYBRID -> EG-EK / DC 8 04-15-2003 11:09 PM
Basic turbo question zueke Forced Induction 6 10-28-2002 06:04 AM
© 2001-2013 HondaSwap.com
