Blow Off Valve Sound
Old 08-20-2003, 03:10 PM   #1
Rep Power: 15 import_racer is off the scale
When I switch gears, and once I get into the next gear, the blow off valve sounds gets cut off. Is that normal? In videoclips, I hear the full sound of the blow off valve. With mine, when I shift, you hear the blow off valve but once I get into the next gear, it goes away. So if I shift quick, you only hear it for half a second or so.
_______
import_racer is offline   Reply With Quote
Old 08-20-2003, 03:21 PM   #2
Rep Power: 15 MarkJimenez99 is off the scale
Check your blow off valve adjustment. Your BOV is probably set to "Hard" which means that you have to rev it really high to hear the full sound. My Greddy type-s bov adjusts by turning a screw.
MarkJimenez99 is offline   Reply With Quote
Old 08-20-2003, 03:43 PM   #3
Rep Power: 47 liquid00meth is off the scale
Send a message via AIM to liquid00meth
indeed, that would be true especially with a smaller turbo and/or low boost levels. Not as much pressure would build up, and if the BOV is set too tight it will shut early.
"Our enemies are innovative and resourceful, and so are we.
They never stop thinking about new ways to harm our country and our people, and neither do we."
-The thought provoking George W. Bush
liquid00meth is offline   Reply With Quote
Old 08-26-2003, 05:27 PM   #4
How do you loosen it? Tighten the screw or is it the other way around? I have a vortech bov that came with the kit. Thanks.
Old 08-26-2003, 07:22 PM   #5
Banned
Rep Power: 0 Loco Honkey is off the scale
_______
That would be normal. See, the BOV only opens when your throttle is closed and your manifold is in vacuum. Once you get to the next gear and crack the throttle, the BOV closes. These other guys are right, but they're not on the right track to answering your problem.
Loco Honkey is offline   Reply With Quote
B Series Cam Guide JDMilan Reference Materials 35 04-13-2007 09:26 PM
Digitally Imported Trance Cashizslick Members' Lounge 12 02-20-2005 04:40 AM
blow off valve darwins_vtech Forced Induction 16 03-11-2004 12:50 PM
Trance Songs Luke6 Members' Lounge 30 08-12-2003 01:39 AM
Oil Shooting Out Of Blow Off Valve... Tonyd0821 Forced Induction 20 06-23-2003 06:27 PM
