boost cooler?
Old 09-14-2009, 01:06 PM   #26
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
Originally Posted by awptickes View Post
Now many engines use methanol compatible coatings. I can't say the same for Al charge piping. All I can say is just paint/powder coat it.
Exactly, the first thing I need to replace is my aluminum charge piping setup. I think I'm going stainless, and I'll need to do something about the coupler to the throttle body as well.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 09-17-2009, 11:22 PM   #27
Rotary Man
hunter4life's Avatar
Ride:  1991 Mazda Rx-7
Rep Power: 31 hunter4life has much to be proud ofhunter4life has much to be proud ofhunter4life has much to be proud ofhunter4life has much to be proud ofhunter4life has much to be proud ofhunter4life has much to be proud ofhunter4life has much to be proud of
...Well I don't know why people knock water meth..it's a really awesome upgrade used properly.....Yes it's a very good idea to tune your car after, (done this upgrade many times, so have friends). Snow performance has also been along for a long time, and in my opinion makes a really good kit. No you don't want a mix over 50/50 for obvious reasons. Washer fluid works fine (blue stuff) and I have not seen any negative affects over the years, from using this stuff then pure "boost juice" you can buy. I can see where there might be a mineral buld up...but it's very minor. As mentioned before it allows you to run higher boost and is a lot safer as everything stays much cooler and yes it's like your car is running on a higher octane...higher then 110. They work really well, perhaps the most impressive gains in hp I've seen are from meth injection. My buddy has a Srt-4 and he gained 70-80 hp on a dyno. For 300-500 bucks I think it can be a great purchase for a turbo car.
An ounce of action is worth a ton of theory. - Friedrich Engels
*Posted a few pics of the rex on my profile*
My Ride(s)
91' Fc Rx7 N/A (first car, wrecked by older lady)
87' Tii Rx7 (second/current car)
92' Honda Civic Hb (Dd/Winter Beater)
hunter4life is offline   Reply With Quote
Old 09-17-2009, 11:28 PM   #28
Ride:  1991 civic hatch dx
Rep Power: 5 Bobby17772 will become famous soon enough
I think that's a great explanation, rep +1
Bobby17772 is offline   Reply With Quote
Old 09-18-2009, 02:14 PM   #29
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
red+ also
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 09-18-2009, 02:36 PM   #30
Rotary Man
Just got a new kit for another car from snow performance (stage one). They have the upgraded pump now which I believe is around 220psi, and really is just a better pump all around, plus the hook ups for the hoses are the easiest thing ever. The kit if anyone is wondering comes with different nozzels depending on your performance application (psi your running, easily explained in manual if you don't know) Everything you need is there, the reservoir , wiring , blah blah. It's an easy installalation to, just time consuming. Will definitely take a few hours. You should be impressed with the power gains though.
My Ride(s)
stage 2 Snow Performance Boost Cooler (complete kit) RSS-Bot Auctions 0 11-26-2008 07:17 PM
H22 have an oil cooler? jeffie7 Prelude 0 03-27-2007 07:45 PM
Cooler Si Eighty-Nine Si HYBRID -> ED-EF / DA 4 06-22-2006 02:06 PM
This guy is way cooler TurboMirage Auto Multi-Media 13 06-09-2005 03:18 PM
N-ter Cooler Sprocker Forced Induction 16 01-21-2003 07:15 AM
