Facebook Twitter
Boost ga. reliability vs. Map sensor readings...
This is a discussion on Boost ga. reliability vs. Map sensor readings... in the Forced Induction forum
The other day I noticed something... my autometer boost gauge shows me maxing out at 14-15 psi right now. My Apexi S-AFCII (used for gauge purposes only) tops at 82kpa (converted to 11.9Psi). With the SAFC getting that reading from a Motorala 2.5BAR MAP sensor, ...
Old 01-31-2008, 07:54 PM   #1
rfrumusa01's Avatar
Default Boost ga. reliability vs. Map sensor readings...
The other day I noticed something... my autometer boost gauge shows me maxing out at 14-15 psi right now. My Apexi S-AFCII (used for gauge purposes only) tops at 82kpa (converted to 11.9Psi). With the SAFC getting that reading from a Motorala 2.5BAR MAP sensor, which would you say is more accurate?
The analog boost gauge, or the S-AFC??? It would be nice to know how much boost I am ACTUALLY running!
Thanks!!! Pls post any experiences with this topic!
rfrumusa01 is offline   Reply With Quote
Old 02-01-2008, 12:57 AM   #2
INJEN78's Avatar
maybe the boost gauge has a little air leak???
id go with the safc if its all wired up correctly
Old 02-01-2008, 05:41 PM   #3
rfrumusa01's Avatar
If it had a leak, it would be reading less boost instead of more... I guess I don't understand how the voltage output from the MAP sensor can relate to an exact amount of actual pressure. I would think the analog gauge reading directly from static pressure (if calibrated correctly, and it should be) would be more accurate. Nobody else?? anyone??
Boost for Newbs Uncle Buck Forced Induction 1 12-06-2007 04:17 PM
WHITE smoke under boost MXDesa Forced Induction 9 10-20-2006 01:32 AM
turbocharged or supercharged for ls/vtec? Loil Forced Induction 13 01-11-2004 09:07 PM
Digging up Turbo Vs Superchargers Silverchild79 Forced Induction 36 01-03-2004 10:58 PM
if you weren't in chat tonight.... pissedoffsol Members' Lounge 33 10-15-2003 11:30 PM
© 2001-2013 HondaSwap.com
