dis is why im not
Someone smack me if this is a stupid question.
When I got my turbo kit it came with a turbonetics bov. That makes a sound I can not stand . So I picked up an old HKS bypass valve for free. I didnt know it was a bypass valve when it was giving to me . I looked it up online and this is what it looks like ![]() Whats the difference between the two ? ![]()
Vouches- sleeper88, civicious, stock95, b18a1build Favorite sites: http://www.gen5alive.com/forums/ http://www.cb7tuner.com/vbb/index.php http://www.cd5tuner.com/vbb/index.php http://forums.nasioc.com/ http://www.vadriven.com/forums/ |
HS RA
same thing.. have you even tried googling it
dis is why im not
I think the difference is that a bypass valve is for MAF cars, and bypasses air from charge pipes back into intake pre-MAF sensor.
Blowoff lets out air unmetered, as well as bypassing it from charge pipes. So I guess main difference is one vents to atmosphere, and one doesn't? Which one should I use them ?
Vouches- sleeper88, civicious, stock95, b18a1build Favorite sites: http://www.gen5alive.com/forums/ http://www.cb7tuner.com/vbb/index.php http://www.cd5tuner.com/vbb/index.php http://forums.nasioc.com/ http://www.vadriven.com/forums/ Last edited by boostedf22; 08-13-2007 at 05:30 PM. |
HS RA
i know shit about turbos.. so i wouldnt be a useful resource .. but they look the same to me..
#5 |
dis is why im not
I'm sure Blanco knows.
#6 |
ok i kno a little bit about this... the blow of valve will let it all out at once and may cause your car to run a bit lean because the ecu is expecting more air and may cause gas to not get bunt and pass into the exhast system and cause flames out the tail pipe... the bypass i do belive lets out the presure but also puts it back into the intake and cause the car to run the right fuel mixture.... its something like that, but i would double check with another person that may be more experianced
#7 |
RETIRED
hondas run map, not maf, so a re-circulating valve is not needed
(thats why all the 240's and drift cars and shit back fire flames... they are running a normal bov, which causes the fuel to ignite in the mani and flame out) you're better off with a BOV. i'd suggest the Tial 50mm. sounds sweet and not ricey like the greddy |
| B Series Cam Guide | JDMilan | Reference Materials | 35 | 04-13-2007 09:26 PM |
| gsr whp | 94_gs-r | Engine Building | 100 | 01-15-2007 10:00 AM |
| AEM bypass valve - no good? | IntegraRC | General Tech and Maintenance | 10 | 08-02-2005 11:59 PM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| blow off valve | darwins_vtech | Forced Induction | 16 | 03-11-2004 12:50 PM |
