| | #1 |
| Member | i have a d16z6 running 6 lbs of boost, DSM 450 injectors, 3in exhaust, and i want to get an adjustable cam gear (not sure what one yet). But how would i know where i have set the advance or retard? Don't you want to retard the timing on a boosted setup? Thanks Last edited by CiViC>ALL; 01-16-2008 at 10:27 AM. |
| | #2 |
| Bean Cakes Join Date: Nov 2007 Location: Rochester, NY
iTrader: 0 / 0% Ride: 97 Civic Turbo / 88 CRX Si LS/Turbo
Rep Power: 6 ![]() | Guess it depends on your setup. I have a built y8 running 16psi with dsm 450s and 3in. like you. My timing is advanced 5 degrees. The ignition timing is what should retard based on boost. It is supposed to progressively retard the ignition timing throughout the power band, per manifold pressure. If you have the ECU chipped, usually they will map the ignition timing like mine, or MSD makes a boost retard controller which essentially has the same effect. My personal opinion is not to mess with those things unless you get it on a dyno... if you set the cam timing wrong, it is really easy to loose a lot of power if the valves do not operate when they are supposed to. good luck.
__________________ 88 CRX Si Boosted B18A - Project lacking initiative 97 Civic EX Boosted Y8 - 12 Second daily driver "You know, I'm sick of following my dreams, man. I'm just going to ask where they're going and hook up with 'em later." |
Similar Threads | ||||
| D16 Turbo Manifold | CiViC>ALL | Forced Induction | 6 | 12-13-2007 11:09 AM |
| 96-00 Civic D15 D16 Rev Speed T3/t4 Complete Turbo Kit | RSS-Bot | Auctions | 0 | 11-09-2007 03:13 PM |
| 170,xxx mile turbo d16...POSSIBLE???? | SPEEDFREAK0920 | Forced Induction | 5 | 03-13-2006 11:52 PM |
| Is there a Supercharger kit | chap_e77 | Forced Induction | 3 | 08-26-2003 06:09 PM |
| D16 turbo questions | SolLess16 | Forced Induction | 12 | 08-20-2003 05:50 PM |
