Facebook Twitter
D16Z6 turbo
Old 05-31-2005, 09:59 AM   #1
chops95ex is off the scale
is a T25 a good turbo for a Z6 engine? A friend has 2 of these and said i could get one for little or nothing. they came off a JDM SR20. It has minimal shaft play, and could use to be cleaned up. all flanges come with it. Will finding a manifold be a problem? How much boost can i possibly run with this? Not sure exactly how he got them but, ones going one his 240,the other is mine if i want it.
chops95ex is offline   Reply With Quote
Old 05-31-2005, 10:02 AM   #2
learning in progress
formby's Avatar
formby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud offormby has much to be proud of
you can use it
boost depends on set up
youll need an adapter plate for the mani
go to www.homemadeturbo.com for on the fly info
Old 05-31-2005, 10:25 AM   #3
The Trisexual
92civicb18b1's Avatar
Ride:  2007 Civic, 1995 Jeep Grand Cherokee
92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of92civicb18b1 has much to be proud of
Send a message via AIM to 92civicb18b1 Send a message via Yahoo to 92civicb18b1
its a decent turbo...
you'd be better off with just about any t3 though.
I think the t25 flows the same as a t3 but is harder to make compatible...It can be done but a little extra work will be needed.
Like formby said, you'd need an adapter plate for the mani, where with the t3 you can find premade t3 flanged mani's easily and cheap.
Your going to also need a completely custom DP, which also isn't hard but it's extra work. Might as well while you do it make it 3". A couple 90* bends and a couple flanges and you're done...but again, the work is there.
DO NOT PM ME WITH TECH QUESTIONS!!!
Current Rides
1992 Chevy S-10 Ext. Cab
Previous
1992 Civic DX Hatch
= 1994 B18B1 Turbo
Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned,
253whp
1994 Civic VX Hatch, 1992 b18a1 swap
1993 Civic CX Hatch, 2000 B18b1
92civicb18b1 is offline   Reply With Quote
Old 05-31-2005, 08:49 PM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond reputeCalesta has a reputation beyond repute
Nope. It's going to take you the same amount of work to use a T25 as it would a T3... and they do NOT flow the same.
Old 06-01-2005, 10:03 AM   #5
so it would be worth $50 then right? i have the means to fabricate a down-pipe.
and i dont think the flange will be a problem. he has the factory flanges for the intake and exhaust sides.
Old 06-01-2005, 10:08 AM   #6
formby's Avatar
go for it....cheap FI set up.....nothing like the sound of a BOV
Old 06-01-2005, 10:22 AM   #7
The Trisexual
ehh, kinda. I should have said it's harder to find parts for. I can't read flow charts or I would compare but I thought they were pretty similar.
Old 06-02-2005, 07:04 AM   #8
thanks guys
Old 06-06-2005, 10:16 PM   #9
fakthepolice is off the scale
fakthepolice is offline   Reply With Quote
Old 06-07-2005, 08:03 PM   #10
Calesta's Avatar
Ride:  2003 S2000
Learn to read the compressor maps.
© 2001-2010 HondaSwap.com
a SkeyMedia Network site
