Dohc zc + boost?
Old 06-04-2009, 03:31 PM   #1
Ride:  94 CX Hatch D15B and 00 Civic EX
Rep Power: 0 JDMBoOsT can only hope to improve
myspace
Default Dohc zc + boost?
I just a 91 hatch with a dohc obd1 zc with a boost kit. i just did a full OEM rebuild. My set up is a egay 50 trim with dsm 450's and FMU and front mount. my question is how much boost can i run safely with a fresh oem rebuild. my ecu is tuned with a sst chip tuned on chrome on 11lbs, is this safe?? any feedback on boosted zc's would awesome.....thanks
JDMBoOsT is offline   Reply With Quote
Old 06-04-2009, 04:00 PM   #2
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
if you have crome, why do you have an fmu at all? remove that.
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
B is offline   Reply With Quote
Old 06-04-2009, 06:17 PM   #3
Ride:  1991 Honda CRX
Rep Power: 2 ZCHONDACRX91 is on a distinguished road
You can run 8 maybe 9 Psi with a OEM setup, you can run 11 PSI, but you should tune it really good. I would just do 7 psi if it's a daily driver and the engine hasn't been broken in yet, or 9 PSI if the engine has been broken in. 7 or 8 PSI is a good setup. The set limit for the ZC is 250 HP and 9 PSI safely. It's all up to you.
ZCHONDACRX91 is offline   Reply With Quote
Old 06-04-2009, 07:28 PM   #4
B
Administrator
B's Avatar
myspace  FaceBook
you obviously have NO idea about turbocharging.
Old 06-04-2009, 08:01 PM   #5
myspace
well i dont have a fuel preasure regulator, all i have for fuel is the dsm 450's.
also the motor has not been broken in yet i just got the head back from the machine shop today and hopefully tomorrow ill have it all ready for the motor to be dropped in.
Old 06-04-2009, 10:55 PM   #6
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
Rep Power: 21 TurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to behold
Send a message via AIM to TurboRex90 Send a message via MSN to TurboRex90 myspace  FaceBook
i agree.
Ive been down this lane. Its not about how much boost, its about what your power goal will be, whats the dynamic compression and other variables. Talk to a tuner and let them decide whats best for your car when they finish the tune.
And btw OP, you need to upgrade your fuel pump with those injectors. Walboro 255lph is good for those size injectors.
Boost is not a hobby, It's pure addiction.
Originally Posted by cjvictoria View Post
nigga... i don't have a bike lol... i have a neon.
Wanna check out my build progress?
http://www.cardomain.com/ride/3029308
TurboRex90 is offline   Reply With Quote
Old 06-05-2009, 06:24 PM   #7
Boost pressure has a lot to do with what the engine can handle, because you add pressure to the motor. Even if it is a little T25 turbo with 9 PSI if you turn it up to 14 PSI and don't tune it right it will blow, before you make 250 HP. Break the motor in for at least 1,000 miles before you boost it, or you will just break period. For the ZC it's either 250 HP or 9 PSI, which ever comes first. It's simple, I've learned from the best tuners, boost = more pressure, more pressure = more stress on the engine. It don't matter how much hp you make if you are running a shit load of boost, you'll blow up.
Old 06-08-2009, 09:24 AM   #8
yep....mmhhm.......yep...
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Rep Power: 83 DESPAIN has a reputation beyond repute
DESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond reputeDESPAIN has a reputation beyond repute
Send a message via Yahoo to DESPAIN myspace
you CAN NOT make 250whp unless you have a very good tune!!! and alot more than just a turbo. you need injectors fuel pump chipped ecu and that is just to start with. i know this from trial and error!!!
Hugh.......I like money.......
"idiocracey"
Originally Posted by DarkHand View Post
Strippers eh? That'll get you a good view of the elusive pink snapper, but don't try to catch the ones around there, they usually have parasites.
Originally Posted by phyregod View Post
Probably waiting on an equipment upgrade.
"This tower runs hondaswap, Those 14 racks over there run the GF pic threads"
DESPAIN is offline   Reply With Quote
Old 06-08-2009, 12:34 PM   #9
B
Administrator
B's Avatar
myspace  FaceBook
lol, no.
again, you don't have a clue about turbo charging.
Old 06-08-2009, 03:06 PM   #10
myspace
lol, no.
lol this poor guy is getting all kinds a bashed on all over HS..lol
Anyway, an update on my build, Head is on and yesterday we put the timing belt on and timing set perfect, then relized i forgot the timing belt cover and had to ripp the belt back off, and had to take the exhuast cam gear off, then when i went to put the cam gear back on the damn bolt broke, so that stopped me for now, i have now got the bolt i need, so hopefully here in about an hour ill be heading to the shop today. Im hoping ill have everything assembled on the engine stand and ready to be dropped back in.
Old 06-15-2009, 12:01 PM   #11
I'm sure you know a lot, but show me. You all are fucking ricers! It's not that fucking complicated, with the ZC DOHC, you can put 250 HP (not 250 WHP) at it or 9 PSI. I know this from experience and others. Of course you need upgraded fuel system, but it's all about tuning everyone knows that except you guys. Now I know what everyone says that this full of RICERS and it's the worst honda forum around. You say I'm wrong, but you don't say why, that proves you don't know shit.
Old 06-15-2009, 03:43 PM   #12
B
Administrator
B's Avatar
myspace  FaceBook
you're right, i know NOTHING about turbocharging.
Old 06-15-2009, 04:51 PM   #13
DESPAIN's Avatar
Ride:  92 PRELUDE SI
thats a cool sheep's horn manifold........ everyone knows psi is same as hp. but not whp....lol
"idiocracey"
Old 06-15-2009, 05:01 PM   #14
B
Administrator
B's Avatar
myspace  FaceBook
even that statement is wrong.
psi is the measurement of pressure at the map sensor. nothing more. it DOES NOT equate in ANYWAY to horsepower. torque, etc without other known factors, such as the particular turbo's cfm rate at what surge limit and all the rest
Old 06-15-2009, 05:13 PM   #15
DESPAIN's Avatar
Ride:  92 PRELUDE SI
hense the lol........ i dont see how 250hp and or 9 psi makes any sense.......lol
"idiocracey"
Old 06-16-2009, 01:31 PM   #16
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
this thread makes me Lol everytime i read it.
If 250hp = 9psi.
Damn that must mean thats like 27.8 hp per psi! OMFG so my 19psi setup is really making 528.2 hp?! HOLY SHIT.
Dumbass. Not all turbos put out the same amount of pressure. otherwise why would they make larger turbos and smaller ones?
ZCHONDACRX91: You say were all ricers, wheres the proof you have any knowledge or experience at all? Just because you search on the internet doesnt mean you know anything. Lets see what your car looks like.
and B, damn.. i didnt know how sick your ride was.
+rep
Old 06-16-2009, 02:48 PM   #17
DESPAIN's Avatar
Ride:  92 PRELUDE SI
Yeah its funny how people think psi is same as hp. There are so many variables involved. Iam new to turbo shit. But i have done alot of research and its not hard to get the jist of it. People need to reed and learn instead of trying to sound like a fucking fast & furious movie................. yeah spelling sucks. to lazy to fix
"idiocracey"
Old 06-16-2009, 03:09 PM   #18
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
I still like B's setup. haha
Old 06-16-2009, 04:52 PM   #19
B
Administrator
B's Avatar
myspace  FaceBook
she was short lived.... lol the block i bought used was toast (main bearings where shot) and i just gave up on it and parted it out, threw a b16 in the car and sold the car for an sti.
Old 06-17-2009, 01:52 PM   #20
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
Damn, how much did you invest into that project?
Old 06-17-2009, 03:36 PM   #21
B
Administrator
B's Avatar
myspace  FaceBook
wayyy tooo much.
Old 06-24-2009, 01:24 AM   #22
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
What size turbo did you have?
And how much power did she make?
Old 06-24-2009, 01:52 AM   #23
K2e2vin's Avatar
Ride:  88 Honda Civic HB
Rep Power: 150 K2e2vin has a reputation beyond reputeK2e2vin has a reputation beyond repute
Send a message via AIM to K2e2vin  FaceBook
SC61?
Anyways, there's more to making power than PSI. Sure, it's relevant, but as stated before you have to take into account the compressor flow(which effects the pressure at x rpm); then there's tuning which involves fuel compensation and ignition timing.
1988 Honda Civic Standard-more mods than I want to list
1992 Honda Accord LX
1996 Toyota Avalon-Spun bearing, for sale.
Terrorists have successfully attacked our imagination.
RIP
Jon Eban Nie, August 31, 1991 - May 7, 2006
Y-Daniel Siu Eban, September 7, 1986 - May 7, 2006
Old 09-09-2009, 08:10 AM   #24
Greenhorn
Rep Power: 0 brandiesel is on a distinguished road
im trying to do the same boost a dohc zc. i have sohc head too. where cani get info on this. the turbo is 14b mitsu. which is better? is there a build somehwere i can refer to?
brandiesel is offline   Reply With Quote
building a zc dohc for boost Fernpatch Engine Building 3 05-22-2009 11:10 PM
f22b dohc boost zap45 Forced Induction 1 03-08-2009 10:25 PM
d16 dohc boost? competitiveaudioman Forced Induction 12 02-06-2008 11:05 PM
Acura : CL DOHC VTEC Acura CL ONE OF A KIND 45K DOHC, NOT, CIVIC, INTEGRA, RSS-Bot Auctions 0 01-19-2008 02:03 AM
F22A1 or DOHC F22B for boost? foamypirate Forced Induction 1 09-18-2006 03:38 PM
