Meeeeooowww!!!!!
the drain from the turbocharger 2 oil pan is really really really close... like so close its hard 2 bend the line to fit i tried shortening the line and its 2 short 2 bend.. so i was either thinking hard line or 2 45 degree angle fittings with a straight line.. but idk
#6 |
Meeeeooowww!!!!!
ill try 2maro.. there prolly is im juss over thinking it... lol its cause this the pretty much the only thing holding me bacc cause i get my new turbocharger on friday and i wanna have everything ready so i can juss bolt everything up...
#7 |
F.I. Junkie
Ride: 1996 Civic, 1992 Accord
You can always go with rubber hose. It's more flexible and won't kink on you. I'm running a piece on my setup right now because the braided line wasn't flexible enough for what I had going after I put my Moroso pan on.
What kind of manifold is this, and where is the drain setup to go into the pan? __________________
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6- |
#9 |
F.I. Junkie
A mini log and it sits really close to the pan? Strange.
What turbocharger is on the car at the moment, and is it the turbo you will be using when the car is running? Also, I'd suggest trying to re-clock the turbo. You might be able to change the angle of the drain in order to keep it from kinking on you. __________________
-320 WHP EJ6- |
#10 | |
seņor member
Ride: 95 Teggy
I have seen two take a shit at the strip, talk about fucking everyones day. Use braided lines, do what you may to get oil to the turbo but please use braided lines. __________________
Tired Of Having My Car Broken Down Will Some One please Slap Some Knowledge In My Head? Reptiles Rock! |
#11 | |
F.I. Junkie
-320 WHP EJ6- |
#12 | |
yep....mmhhm.......yep...
Ride: 92 PRELUDE SI
yes i have a high temp goodyear hose and it works just fine. i am pushing 18psi and about 400+hp. and i have had no problems out of mine. that being said. make damn sure your oil feed line is top notch. steel braided and of a good brand. mine was about 60$.
Hugh.......I like money....... "idiocracey" Quote:
#13 | |
Meeeeooowww!!!!!
#14 |
F.I. Junkie
Yeah, try re-clocking it. I just can't see how a log manifold would create a problem such as this. Pics would be best, I could probably give you an idea of how to clock the turbo from there.
-320 WHP EJ6- |
| Oil Return Drain Line Kit Civic Integra B16 B18 D15 D16 | RSS-Bot | Auctions | 0 | 07-14-2009 03:50 PM |
| Oil Return Drain Line Kit Civic Integra B16 B18 D15 D16 | RSS-Bot | Auctions | 0 | 04-21-2009 03:50 PM |
| Civic EG EK B16 B18 D15 D16 Turbo Oil Return/Drain Line | RSS-Bot | Auctions | 0 | 04-20-2009 09:36 PM |
| Question about tapping oil pan for drain line | 95EGCoupeVtec | Forced Induction | 7 | 04-13-2009 01:11 AM |
| Blitz Dual SBC Spec S, SS Oil Feed Line & Fittings, Oil Drain Line | LSEGHATCH | Parts: For Sale/Trade/Wanted | 4 | 12-13-2005 07:35 PM |
