#26 |
The Trisexual
Ride: 2007 Civic, 1995 Jeep Grand Cherokee
They're parts are the lowest quality available. They fall apart, the manifolds crack, the turbos are "glued", yes GLUED together or at least they used to be. I doubt they improved much but I strayed away from them so I don't have personal experience. Maybe someone with actual experience will chime in.
DO NOT PM ME WITH TECH QUESTIONS!!! Current Rides 1992 Chevy S-10 Ext. Cab Previous 1992 Civic DX Hatch = 1994 B18B1 Turbo Rebuilt Garrett .60/.48 T3, log style mani and DIY downpipe, DSM 440's, kteller IC piping, JRC Intercooler, Home Depot style oil lines, HKS BOV, Crome Tuned, 253whp 1994 Civic VX Hatch, 1992 b18a1 swap 1993 Civic CX Hatch, 2000 B18b1 |
#27 | |
Plus , we don't know if the person that is looking for help, earns 20k a month, or if is just a person who wants to start a proyect with a reasonable budget, Is hell nice to have a turbo installed and working properly, its a kool feeling but not everybody can buy a garrett or turbonetics ballbearing. or a HKS BOV if you know what I mean. Everybody knows that a KIT it's a plug n' play process. and that's why the cheap turbos kits are so considered as bad ones I installed those kits here in my country several times and I know they are not good quality, but if you use your common sense and realize that you need to add certain tweaks everything will be fine, p.e : yes , the manifold cracks , but if you add two supports between the manifold flanger and turboflanger and you add a suppoort between the turbo flanger( two bolts ) and the block , the header will not break ($30), I have clients with that tweaks and they don't have any problems and they have years with the kit installed. the turbo is not glued, well at least not anymore, if you take care of them they will not have a problem at all, and you know what, I can say they last at least 2 years, and if that's the case, well , you have two options. either wait until it gets fucked up and get a expensive one that last 5 years or more, that cost 5 times more, or spend another $200 bucks for another two more years, and let me tell you something, if you are considering the ebay cheap ones, that means that is not a very serious racing car ( non daily driven car ). if you have a nice budget , get expensive good quality parts, that way you will not have the hassle to change stuff every certain amount of time. but if you don't, get an ebay kit, and I can help telling you what you can do to make that a little more secure and reliable. One more thing, I wouldn't use cheap parts for over 300whp ! , at that point a failure is too dangerous, it's better to be in a more secure point Thanks __________________
Ride: B16A JDM SiR-II - Hatch 92 - WISECO Piston Kit STD - Eagle Rods - Walbro 255lph - AEM Wideband - CROME PRO - T3/T4 Turbo Kit - RamHorn Style - DSM 450cc Injectors - TiAL 38 MM External WasteGate - Integra Front Brake System - Mugen Valve Cover Red - NGK Iridium Spark Plugs Last edited by amadeuscr; 03-26-2008 at 09:55 PM. |
#28 |
The Trisexual
to each their own, it's not my money or my car. I personally wouldn't put it on my car.
#29 | |
decapitates emo kids
Ride: A hard bargain
Gutted 95 DX w/ LS swap |
#30 |
The Trisexual
it was meant to be.....
#31 |
Sonnova Bitch!
Ride: 2006 GSX-R 600, 2003 Santa Fe GLS
I hate these threads. I don't know who to answer.
Ebay turbo's are shit. If you want your turbo to work like shit, then by all means, buy one. Everyone can't afford a Garrett or HKS, all at once. There's no reason that someone can't afford one though, it's just that they can't afford it right now. So be patient. Let's consider the options: Buy cheap e-garbage scenario: Install it, works fine for about 2 days, after enough heat and abuse, turbo starts to fail. The seals start going, and the glue starts coming loose. The turbine obtains a ridiculous amount of play, and suddenly, you're motor locks up. Now you're out a turbo, and an engine. Pinch pennies, and buy something of good quality: Install it, and works great while you use it, and untill you decide to sell your setup/car/motor, or you total your car. Or it just works great for the next 15 years. You've just saved about $600 by switching to high-quality parts. Nothing turbo is plug-and-play, that's a huge misconception. It all usually takes a little modifying, and then there's the whole tuning deal. Like I said, I'd rather shit on my engine. __________________
http://davesstainedglass.webs.com/ |
#32 | |||
Brutal Moderator
Ride: 97 Integra LS Coupe
That makes no sense to me. My advice for someone on a budget would be to have some patience, save up their money, and do it right the first time by buying quality parts. It will actually be cheaper in the long run, since the parts are less likely to fail and less likely to damage your car's motor than the cheap E-Bay crap is... Quote:
![]() __________________
#33 |
ok this is thing, why would i post asking a question if i had all the answers isnt this a forum where people come get info on stuff they arent sure about, this is what i am planning to do iam going to take the risk and use this turbo kit on my b18b motor, and i will pm amadeuscr to let know exactly what he did for it work decent, reason being i have heard anybody comment yet that has actually blown the motors with ebay kit, it more speculations, the one guys actually owns a kit, with a little mod, it works fine. When my h22 is fully built and complete i will invest in quality turbo setup, so with all that out the way can we answer my original question "HOW MUCH HP DO YOU GUYS THINK I CAN GET OUT OF THAT TURBO KIT" in b18b not the h22 LOL, HP AND TORQUE VALUES ONLY PLEASE..
#34 | |
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
and when you go start your own thread, list what you have done to the motor. you obviously only value your car as much as the value of the parts you put in it. so why use cheap ebay shit. i'll tell you this much, i would NOT trust an ebay wastegate for the life of me. if you get the turbine, it's just going to be a waste of money 2 steps backward for one step forward.... |
#35 |
LOL, why all the anger buddy, it just a forum, and now , about a page later ,you want to point out that iam thread jacking, hahaha you make me laugh.... by the way lets respect him and do as he wishes, i dont have anymore interest in this topic thanks,
not from people like ybegal anyways... thanks guys... |
#36 |
your the one that was getting mad because nobody's talking about your question. and there's a difference between asking a related question and thread jacking. you started off ok, but go start your own thread. your asking questions now completly unrelated to this thread's title.
and it's still page 1 to me, since i have the option set to view 100 posts per page. not a big deal to me. since you type in all caps i assume your stressing it like your angry yourself. but lets answer questions so the noobs can learn. no need to hide them in a topic started regarding something completly different. |
#37 |
Sonnova Bitch!
/unsubscribe
#38 |
F.I. Junkie
Ride: 1996 Civic, 1992 Accord
In all honesty people can say what they want about the quality of the ebay stuff. Some of us just have to see to believe.
Take me, for example. I'll be installing an ebay turbo/manifold on my car just because I want to try it. I wont take a chance on the wastegate, though. TiAL all the way. I know it is a risk, and I could possibly need to buy another turbo/mani. but I want to see if they work or not. If they don't, eh, I learned a lesson and I'll stick to proven products. __________________
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6- |
#39 |
The Trisexual
That was the point of it.
#41 |
The Trisexual
ess you can't read.....
It was meant to be.... Why are you posting the same thing 9 post down? Did you think you were going to get a different answer....or are you unable to keep up with a thread with more then 4 or 5 posts in it? In the future, do everyone a favor and pay more attention to replies. In the present, realize, I've been here longer and your opinion means nothing to me, you're wasting bandwith. I read some of your other posts and you might as well go over to HT with your bullshit. __________________
| Turbo Charging 88-91 Preludes | 1Funryd | Forced Induction | 8 | 06-25-2009 10:24 AM |
| ? about Civic h22 turbo kits | RICE PWRD | HYBRID -> EG-EK / DC | 0 | 07-19-2007 08:14 PM |
| Turbo Kits | import_racer | Forced Induction | 4 | 09-25-2006 01:12 PM |
| Boost & HP Level | Turbo&Auto | Forced Induction | 56 | 09-13-2006 01:18 AM |
| ::Testing Waters:: '95 Turbo d16z6 175WHP @5000RPM | steeze | Parts: For Sale/Trade/Wanted | 6 | 01-09-2005 06:12 AM |
