Which exhaust great for turbo?
Old 09-07-2006, 06:03 AM   #1
gettocrx's Avatar
Rep Power: 14 gettocrx is an unknown quantity at this point
Send a message via AIM to gettocrx
Default Which exhaust great for turbo?
hey guys! I'm done with my turbo install on my EG 4 door sleeper! B16 with turbonectics t3/t04b h-trim. .63 a/r. Problem is my exhaust is still stock so I get a big lag and I am thinking of getting a full after market exhaust system. I'm thinking on getting a Greddy SP2 or Tanabe hyper medalion. Which exhaust sytem do ya'll recommend? remember now it's a sleeper, so quiet and efficient is what I'm lookin for!
GETTO GARAGE: May be GHETTO but we get the job done!
88 CRX: B16A 60-1 turbo
94 HATCH: Daily Driven B16A (RIP)
92 EG8: Daily Driven 4DR Sleeper w/d16z6 t3/t04e turbo
NA IS ALRIGHT! but... BOOST IS BETTER!
gettocrx is offline   Reply With Quote
Old 09-07-2006, 07:48 AM   #2
Nick Go FAST!!
Turbo&Auto's Avatar
Ride:  09 Cobalt SS/TC
Rep Power: 87 Turbo&Auto has a reputation beyond repute
Turbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond reputeTurbo&Auto has a reputation beyond repute
Send a message via AIM to Turbo&Auto myspace
Custom. 2.5 or 3" from the turbo-back with no restrictions is ideal. I'm using a Magnaflow Race mid muffler and no cats.
www.BackyardTurbo.com
Turbo&Auto is offline   Reply With Quote
Old 09-07-2006, 05:24 PM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
3".
Old 09-08-2006, 05:41 AM   #4
gettocrx's Avatar
Will the exhaust size stop the turbo from reaching peak boost? my wastegate is set to 6psi but I dont even reach it. I dont think there's any leak in the charge pipes! But I'll double check anyways
Old 09-08-2006, 07:32 AM   #5
Nick Go FAST!!
Turbo&Auto's Avatar
What size turbo? It may be too big of a turbine housing to spool it fully.
OR
If its an internal wastegate, pull the actuator rod off and make sure there is some tension on it to reach the flapper. This way it guarantees it will stay closed tightly unitl you want it to open
OR
Leaky BOV flange, Leaky charge pipe, something leaking boost
Old 09-10-2006, 09:54 PM   #6
gettocrx's Avatar
well i guess i found the problem! My stock muffler wasn't cutting it.. Too much resriction i guess because when I removed it I'm able to reach peak boost and it spools up much quicker! but I can't stand the sound. do you think a stock itr muffler will be just as good as a aftermarket exhaust?
Old 09-12-2006, 12:38 PM   #7
im turbo bitch!!!!
Ride:  turbo hatch/turbo coupe
Rep Power: 8 tunedhonda-ata is an unknown quantity at this point
you should go 3" or bigger i have 3 on my car and its only loud when i got the boost uppppppppppppppppppppppp but besides that you might look into a greddy my friend had a catback from greddy on his hatch and you couldnt even hear it... but it also had turbo lag..... performance over sound
tunedhonda-ata is offline   Reply With Quote
Old 09-15-2006, 05:59 AM   #8
ccfab's Avatar
Rep Power: 7 ccfab is an unknown quantity at this point
bigger the better, if your worried about noise, run resonators.
i suggest a 3 inch system for anything up to about 550whp, more than that run 4 inch
aluminum with v bands mmmmmm
ccfab is offline   Reply With Quote
Old 10-04-2006, 07:27 PM   #9
Rep Power: 0 primered-hatch is on a distinguished road
i want to turbo my b16a1 . i am going to buy a turbo kit on ebay nothing to strong at first but im going with a complete fuel upgrade and new pistons and rods . what kind of boost do u think i will be able to run with out blowing my motor?
primered-hatch is offline   Reply With Quote
Old 10-04-2006, 08:36 PM   #10
Rep Power: 0 Souri is on a distinguished road
i wouldn't drive too much on that stock exhaust bro. Cuz i have a b16 in my EG with little done to it. On stock exhaust and the back pressures causing "reversion" which is cracking the ceramic tips of my fuel.injecters to crack! b-careful. Oh 3'' perfect for the exhaust. unless u plan on makin it ungodly fast, then go bigger. =)
Souri is offline   Reply With Quote
Old 10-04-2006, 08:37 PM   #11
gettocrx's Avatar
Unhappy
"Technically all turbos can blow that motor up!" " If not all! MOST!"
depending on the tuning but I say go with a t3/to4e .57/.63 a/r. Also try staying away for cheapy ebay turbo kits..
Old 10-05-2006, 03:47 PM   #12
Rep Power: 18 jeffsciv23 is on a distinguished road
Send a message via AIM to jeffsciv23
i would go with a 2.5" summit turbo muffler and 2.5" piping all the way back, remove the cat and it will be great flowing and quite.
jeffsciv23 is offline   Reply With Quote
Old 10-12-2006, 11:15 PM   #13
Well Im probably gona sound like a "Tree Hugger" saying this... But I would really recommend a Hi flow cat. as alternative.Especially wen it's a daily driver. After wat I've learned while attending "UTI" about Emmission and wat not. . I mean There's a very good reason why it is a Federal offence to tamper with emmission devices....If NOT.. Then dont forget your "sun screenz" boyz and girlz...
Old 10-13-2006, 01:02 PM   #14
if thats the case then you should never swap a motor into a differant car because most of the time they never pass emissions.
Old 10-15-2006, 01:38 AM   #15
I need some ligaments!!!
turbo sol's Avatar
Location: laurel, montucky (ten minutes out of billings)
Ride:  89 crx hf, turbo'd 95 del sol si, 87 shaggin wagon(astro)
Rep Power: 17 turbo sol has a spectacular aura aboutturbo sol has a spectacular aura about
Send a message via MSN to turbo sol myspace
i would go for the hi flo cat cause if you want to take it in to a shop and they see that there is no cat they won't work on it for you.(that's how it is here in mt anyways)not saying you don't do all the work on your car but it might have to go in sometime. get the 3" exaust. my friend has a tanabe setup on his civic and it is kinda noisy(in a good way though!) don't know if you should really worry about the noisy exaust if you've got a turbo cause they're gonna hear you spoolin' up and the wistle of the bov is gonna tell em too.
car + vinyl = big hp!!!
wipe your mouth, there's still a tiny bit of bullshit around your lips
Achmed the dead terrorist:
I once threw a penny between two jews and watched them fight to the death! I did the same thing with two Catholic priests except I threw in a small boy! And the winner had to fight Michael Jackson!
(\__/)
( 0.o )
( > < ) The bunny will rule teh world! Bwahahahaha!!!!
turbo sol is offline   Reply With Quote
Old 10-15-2006, 05:44 AM   #16
gettocrx's Avatar
Ok now! I dont know if you read the thread very well but I'm goin for the "SLEEPER" look and sound! And... Here in Hawaii there's no smog test what so ever, so I'm running it with no muffler and gutted cat right now but its still stock piping and resonator! Doesn't sound that loud but would be nice if it was a little softer! Will probably do the 3" cat back or get a greddy sp2 set up! I'm in a budget right now because the turbo set up set me back a little!
Old 10-17-2006, 08:41 PM   #17
Rep Power: 10 danse will become famous soon enough
I'm running a single slam with a T3/T4 57 trim, it starts to build boost at 3100, I have a 2.5 inch system with two resonators and one turbo dynomax muffler. Its quiet but I used a dump pipe for my wastegate and from day one the wastegate does not fully seat, it stays off the seat by about a millimeter or two, I took it apart and there are no adjustments for it. So I am heading back to the muffler shop soon to plumb the dump pipe into the main pipe. Something to think about when you are setting yours up..
danse is offline   Reply With Quote
Old 10-17-2006, 08:56 PM   #18
gettocrx's Avatar
I dont mine the dump being loud @ WOT. It's the daily driving that gets on my nerves. espicially on the freeway reving 3000 goin only 55mph! Yeah I start to build boost around 3000rpm too.
Old 10-24-2006, 12:06 PM   #19
Noob alert! When I bolted on the waste gate I forgot to add the valve seat for the gate. No leaks now and I know some have dynoed using a separate dump pipe and make more power that way. With the 2.5 system and turbo it starts building boost at 2500! this is with a T3/T4 57 trim .63 turbo! And its very very quiet.
Old 10-26-2006, 01:00 PM   #20
Ride:  EG nation
Rep Power: 7 slammedvtec is on a distinguished road
i say if u want quiet 2.5 is the way to go, the bigger u go the louder its gonna be unless ur pushing more air threw it
slammedvtec is offline   Reply With Quote
Old 11-02-2006, 08:29 PM   #21
Rep Power: 7 weirtech is on a distinguished road
if you are happy with 250hp stick with 2.5", if you want more than that, then go with 3". if you are aiming for more than 500hp you will want 4"
weirtech is offline   Reply With Quote
Old 11-02-2006, 08:40 PM   #22
THE killer
zex_cool's Avatar
Rep Power: 7 zex_cool is on a distinguished road
Send a message via AIM to zex_cool
i would recommend any exhaust that you like and just add a e-cutout, THE best thing for a "sleeper" lol
y7 w/16g@8psi 193whp 182tq OLD SETUP
zex_cool is offline   Reply With Quote
Old 11-11-2006, 09:51 AM   #23
Ride:  civic eg
Rep Power: 7 wardatron is on a distinguished road
go sick and get custom 4" straight threw :-) thats my plans for my turbo B16
wardatron is offline   Reply With Quote
Old 11-11-2006, 10:41 AM   #24
Rep Power: 14 divisii is off the scale
" but I can't stand the sound. do you think a stock itr muffler will be just as good as a aftermarket exhaust? " - ghettocrx
tanabe makes great exhausts .. the Concept-g & Medalion are supposed to be pretty quiet.
1999 Civic DX--
AEM CAI, Magnecor plug wires, 195-50/15x7 alloys
future? B or K swap
divisii is offline   Reply With Quote
Old 11-12-2006, 05:02 AM   #25
gettocrx's Avatar
I think I made it one of my options beside an itr exhaust! Thanks though!
stock, audio, z6 head & y8 tranny, aem v2, exhaust, cat 93blkej1 Parts: For Sale/Trade/Wanted 6 10-06-2005 10:39 PM
Magnaflow 2.25" exhaust, First Impression confusatron General Tech and Maintenance 10 09-21-2005 03:04 PM
Sleeper Exhaust del_sol_sleeper General Tech and Maintenance 25 02-09-2004 08:12 PM
Exhaust truoss HYBRID -> EG-EK / DC 5 12-23-2003 10:35 PM
Exhaust on a civic illmatik HYBRID -> EG-EK / DC 22 12-17-2003 08:14 PM
