Fitment Question
Old 06-23-2004, 06:26 PM   #1
Picture of Retarded Cat
Battle Pope's Avatar
Ride:  2007 Civic LX
Rep Power: 171 Battle Pope has a reputation beyond repute
Battle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond reputeBattle Pope has a reputation beyond repute
As some (probably none) of you may have seen in my other (admittedly few) topics, I drive a 5th gen Civic DX Coupe. D15z6 engine, IIRC. Anyway, since the F22 would be a complete waste of time, I have started looking at turbo kits. I've seen some attractively priced kits that are marketed for the 92-95 Civic EX/SI, but not the DX really. What I am wondering is, will a kit (mainly the manifold) for a EX/SI fit a DX engine? I know there are differences in the engines - I'm not a retard (I don't think), but are the differences enough that I should just scrap the kit idea and try to piecemeal one from components?
Originally Posted by Jeremy Clarkson
A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Battle Pope is offline   Reply With Quote
Old 06-23-2004, 06:30 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
the mnaifold will bolt up fine. the exhaust studs are the same.
some of the piping might not bolt up perfectly though
Old 06-23-2004, 06:52 PM   #3
Ride:  2007 Civic LX
Any idea offhand what might interfere? I don't really want to beg/borrow/steal (possibly buy :P ) a kit and have to fudge it up fitting it. <_<
Old 06-23-2004, 07:05 PM   #4
RETIRED
where the intake bolts to the throttle body is porbably going to be slightly off...
Old 06-23-2004, 07:12 PM   #5
Ride:  2007 Civic LX
By "slightly" I'm getting a vibe of "acceptable" or "workable"... Either way, I guess. Better than a hoborigged setup :P
Old 06-23-2004, 07:19 PM   #6
Rep Power: 44 MaaseyRacer is an unknown quantity at this point
Send a message via AIM to MaaseyRacer
if you want to make sure it all fit right you can put an 5th gen si intake manifold on your motor. It will bolt up, and you will see gains from it, the turbo kit will also fit a lot better too.
2004 Toyota Tacoma
3.4L V6
TRD Package
4WD
MaaseyRacer is offline   Reply With Quote
Old 06-23-2004, 11:56 PM   #7
Ride:  2007 Civic LX
Nice suggestion, although at this point I am going to be swapping in a D16 from a civic EX, so assuming my current trans will work, I don't have to change motor mounts, and I can find a wiring harness fairly cheap, the turbo should fit exactly.
The kit is one of the new Edelbrock kits - it was a display at my speedshop so I picked it up for a song!
(EDIT: and by wiring harness I meant ECU :P )
SEO by vBSEO 3.3.2
 | a SkeyMedia Network site
