Fuel pump upgrade?
Old 06-07-2004, 10:40 AM   #1
Rep Power: 15 Johnnylawless is off the scale
cheked the search function, and saw that if I have larger Injectors ( RC750) that I dont need to upgrade my stock fuel pump?I was going to set it at 60 PSI on the regulator. also see my sig for mods except I will up the boost alot 15-25 psi.
---------------1.7Ltr IB Spec Turbo Monster !!!---------------
'95 EJ Coupe, B16A Swap bored to 84mm with GE HD Sleeves,IB Spec JE Pistons,IB Spec SCAT H-Beam Rods,Type R LSD Trans,AEM Adjustable Cam Gears,Fluidyne Radiator, RC 750cc Injectors, AEM EMS Standalone With AEM Wideband UEGO O2 Controller, GM 3BAR MAP Sensor,GM Boost Control Solenoid,Turbonetics Stage 5 62-1 Turbo,2.5" Custom Exhaust, HKS SSQ BOV,Trust Type 31 Intercooler,ACT Streetlite Flywheel,ACT Streetdisc,ACT Xtreme pressure plate,Complete Energy Suspension Kit, 17" Katana Racing rims,Falken GRB FK451 225/35ZR17.
-------Daily Driven,Full Interior,Complete Sound System------
------------------------Certified Sleeper----------------------------
<a href=\"http://home1.gte.net/res0gy53/CARSWAP%20PICS.htm\" target=\"_blank\">My swap Pics (56K Beware)</a>
Johnnylawless is offline   Reply With Quote
Old 06-07-2004, 01:02 PM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
you either read wrong, or searched some shit info.
you need a bigger intank pump. wlbro 255 lhp HP is what you want.... and i hope you have better luck with it than i've been having.
and don't run 60 psi. thats stupid. keep it around 40-45
Old 06-07-2004, 01:18 PM   #3
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
not to shit on your parade but why an ITR??? why gut it for turbo thereby removing the high compression that really makes it a type r?
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 06-07-2004, 01:39 PM   #4
Rep Power: 16 beerbongskickass is off the scale
Send a message via AIM to beerbongskickass
Why a type R? GSR and type R motors with turbos fucking kick ass that's why.
EDIT: Oh yeah a walbro 255 will work fine.
Turbocharged 95 Civic w/stock D16Z6 - 230whp/208wtq thanks to www.HomeMadeTurbo.com and uberdata
beerbongskickass is offline   Reply With Quote
Old 06-07-2004, 04:40 PM   #5
went ITR NA'd for awhile and you always crave more power anyways.
Also a cracked ring land on #3 cylinder has prompted me to have it built IB Spec
"Killer Block"
JIM
'95 EJ Coupe, B16A Swap bored to 84mm with GE HD Sleeves,IB Spec JE Pistons,IB Spec SCAT H-Beam Rods,Type R LSD Trans,AEM Adjustable Cam Gears,Fluidyne Radiator, RC 750cc Injectors, AEM EMS Standalone With AEM Wideband UEGO O2 Controller, GM 3BAR MAP Sensor,GM Boost Control Solenoid,Turbonetics Stage 5 62-1 Turbo,2.5&quot; Custom Exhaust, HKS SSQ BOV,Trust Type 31 Intercooler,ACT Streetlite Flywheel,ACT Streetdisc,ACT Xtreme pressure plate,Complete Energy Suspension Kit, 17&quot; Katana Racing rims,Falken GRB FK451 225/35ZR17.
Old 06-07-2004, 04:44 PM   #6
RETIRED
do it up.
pump it
feed it well
tune it well
make some sick power
Old 06-07-2004, 04:49 PM   #7
Rep Power: 14 [Freemantle] is off the scale
Does it ever seem like you are saying the same thing over and over?
WTB: 88-91 CRX of any trim level -- central Florida area --
[Freemantle] is offline   Reply With Quote
Old 06-07-2004, 04:53 PM   #8
RETIRED
98% of my 24,000 posts are the same thign
Old 06-07-2004, 04:54 PM   #9
Rep Power: 35 NotUrAverage_Si is off the scale
Originally posted by [Freemantle
,Jun 7 2004, 01:49 PM] Does it ever seem like you are saying the same thing over and over?
whoa?
'00 <span style=\"color:black\">FBP</span> Civic <span style=\"color:red\">Si</span>-T
|<a href=\"http://www.full-race.com\" target=\"_blank\">full-race</a>|<a href=\"http://www.goldeneaglemfg.com\" target=\"_blank\">golden eagle</a>|<a href=\"http://www.fast-turbo.com\" target=\"_blank\">fast-turbo</a>|<a href=\"http://www.hondata.com\" target=\"_blank\">hondata</a>|<a href=\"http://www.wiredspeed.com\" target=\"_blank\">wiredspeedlab</a>|
email: boostfedEM1@yahoo.com
<div class=\'quotetop\'>QUOTE(dohch22a4 @ Sep 20 2004, 11:44 AM)</div><div class=\'quotemain\'> Please, Obi Wan B, you're our only hope.
</div>
<span style=\"font-size:36pt;line-height:100%\"> <a href=\"http://www.nissantech.com\" target=\"_blank\">www.NissanTech.co m</a></span>
NotUrAverage_Si is offline   Reply With Quote
Old 06-08-2004, 03:18 PM   #10
Any suggestions of brands (other than walbro) for intake 255lph
Old 06-08-2004, 03:19 PM   #11
RETIRED
msd is the only other brand that i know of... for the same style replacement thinkg, and well, msd uses walbro pumps. lol
Old 06-08-2004, 03:22 PM   #12
Brian,Have you heard of BBK fuel pumps? Any Good?
Old 06-08-2004, 03:33 PM   #13
RETIRED
to my knowledge, they only make inlines... and are thus still limted by tthe stock pump.
Old 06-08-2004, 04:37 PM   #14
Rep Power: 13 spydy43 is off the scale
BBK fuel pumps are made by walbro too I have one and it has the walbro stamp on it.
spydy43 is offline   Reply With Quote
Old 06-08-2004, 05:47 PM   #15
Thanks,no wonder they want $160 for it.
I'll look into a bosch intank if they make one.
