im getting ready to put a gt2052 38mm 50/51 and it is a rather smaller turbo. i think its the size of about a t25. this turbo is gonna spool up to my full boost at like 2000rpm's @ 6psi. (stock motor). im concerned that it will run out of breathe in the higher rpm's. what do you guys think, im trying to reach ~200whp or close to it.
any feedback on this setup on how it will perform? |
#6 |
word, but what about the high rpms, is my power curve gonna drop drastically at 6-7k or will it hold full boost and power all the way through. would there be a a better choice turbo for a stock internal application that will get me SAFELY at 200whp DD?
im going with a fast spooling turbo becuase i dont want a dyno queen ![]() im looking to catch full boost between 2000-3500rpms and make sure it lasts all the way through 7grand Last edited by b16stalyun; 04-19-2008 at 03:53 AM. |
#7 |
whats up blanco!
![]() ight so, when im looking at the compressor maps mine looks like this ![]() looks like i gotta do some research and try to figure out how to read this map. Last edited by b16stalyun; 04-19-2008 at 11:06 AM. |
#8 |
Regular Member w/ Cheese
Ride: 2000 EJ8 w/ SiR-II
Rep Power: 73 ![]() ![]() ![]() |
just so you realize, when your motor is naturally aspirated, the power band doesnt drop off at the top do to lack of air. even at normal atmospheric pressure the motor wont starve of air. the power band wont drop off early due to turbo. that's more dependant on the cam profiles you choose. if anything, you'll reach max boost real early, and it'll just spin max boost for the rest of the power band. it might be all your stock motor needs to max out. either way, once it reaches full boost, that's it, your at full boost, the power will increase as per the motor's natural way. just because boost pressure is not rising, doesnt mean the powerband will fall on it's face.
i think the max psi for a typical T25 is like 25 or 28psi. that's more than i think the stock motor can handle (taking turbo size into account too). after full boost (if it's like 8psi for say), it's the wastegate's job to let any extra pressure escape out of the turbo system, and keep the boost at w/e level you choose. if max pressure is 28psi, and you have it set for 8psi, then 20psi will be blown off, or escaping the pressure system to keep it where it should be. |
#9 |
so if the turbo makes boost real early, will it keep making as much power all the way through lets say 7200rpm. if im driving on the highway at 3800rpm and i down shift into 4th to race somone is the turbo going to still help me gain power up top.
i dont think what your saying is after its done making boost, my motor will perform as if it were n/a. at least i hope thats not what your saying. that may be a stupid question :S after doing the math, if i want 250bhp(should be around ~200whp) airflow: 250*11*.55/60 = 25lb/min manifold pressure 25*639.6*(460+130) / .92 * 7200/2 * 97.6 =29.1 psia=14.7 minus 1 due to filter loss = 13.7 pressure ratio: 29.1 / 13.7 = 2.1 that would put me way off the chart for this specific turbo. isnt that bad? now i know this is a stock motor with 100k, should i even atempt a bigger turbo or more psi? or just be satisfied with this one.
Live for somthing or die for nothing..... Last edited by b16stalyun; 04-19-2008 at 02:08 PM. |
#11 |
it looks like the gt28 would be a better choice turbo. make most of my power around mid-range
i would rather the turbo start spooling around 2500k rpms and reach peak at 6500rpms. unfortunatlly a guy is giving me a deal on this turbo for 300$ so i suppose i dont really have a choice unless i want to spend 800$ on that turbo. do you think it would be safe to run more than 6psi on stock internals @ 100k miles. if so i could go with maybe 8psi. i was gonna go with s/afc and a btm, but i think im going to go with greddy emanage or map 2 ecu. its almost the same price to go with emanage or map 2 than it is to buy both of those. do you think thats a better choice?
Live for somthing or die for nothing..... Last edited by b16stalyun; 04-19-2008 at 10:00 PM. |
#13 |
seriously, here, compare, Spooling Times?
#14 | |
afc sucks. greddy emanage...why? crome! hondata! where do you get these ideas... |
#15 | |
and i heard emanage ultimate was a good tuning device. i was told that if i went with a standalone ecu that my car wouldnt pass obd2 inspection dont you need more psi with this turbo to reach my goal whp? Last edited by b16stalyun; 04-19-2008 at 11:27 PM. |
#16 |
ok, then what does the graph mean if im off the performance islands?
2.1 p/r 25lb/min The T25 turbo used in the 1995-1999 DSMs is a Garrett turbo. This turbo has a .45 A/R with a 45 trim turbine and 55 trim compressor wheel. Note that although these numbers are similar to trim numbers in the T3/T04 turbos you cannot compare them since these wheels are in the T25 housings. These wheels are much smaller than the T3/T04 counterparts. The T25 struggles on a turbo Honda at high RPM but does offer good performance at low and midrange RPM.
Live for somthing or die for nothing..... Last edited by b16stalyun; 04-20-2008 at 12:58 AM. |
#17 |
Ride: 1998 Eclipse GSX
Rep Power: 22 ![]() |
The graph is a representation of airflow as a function of PR with efficiency numbers and compressor RPM superimposed over it.
2052 is small, and will be more expensive than what you could use. If you want 200 whp and 25 lbs/min, look at the stock 1st gen DSM turbo (TD05H-14b). |
#19 |
all it's saying is it cant support high horsepower motors! wow!!!
if your looking to push 500whp and this lil turbo only push's 25psi with low flow, your going to need way more than that amount of air flow to get you to 500whp, thus that turbo would struggle at high rpm where it's already fully spooled to 25psi and can't go higher where you otherwise would like it to. on your stock motor, you only want 200whp, which is easy with a TDO5H-14b. you wont use anywhere near 25psi to accomplish 200whp, so thus the turbo will not struggle. it will produce it's max psi required to attain 200whp, then the wastegate will begin blowing off excess. and thus you will have lets say 8psi from 3,000rpm, all the way to redline, producing exponential power output based on the motor's build nature. btw i'm putting a TDO5H-14b on my stock 10.4:1 B16A this winter. and looking to get 200whp daily. so..............ya. |
#20 |
alright, i got it. i thought that if i was off the graph it was a bad thing and it would hurt my turbo or overwork it or it would stop making power when it went off the chart.
i thought the more psi you push the more power you get and the more you have to re-enforce your motor. for example, so if i wanted 250whp with this same turbo, wouldnt i have to increase psi to reach that goal? AND do you have to re-enforce your motor to run more pressure. even though it will be less than >250whp
Live for somthing or die for nothing..... Last edited by b16stalyun; 04-20-2008 at 10:03 AM. |
#21 |
![]() thats really what i was meaning when i said start spooling at 3 and top at 6, i meant thats where i want my powerband to be. youll have to excuse me sometimes im a fucktard. ![]() anyway, as far as the rest of the setup any feedback you can give me? greddy emanage ultimate(shop said i wont pass obd2 inspection if i went with standalone ecu) EGT, boost and wideband 440cc injectors i will post dyno pic's in about a week or so Last edited by b16stalyun; 04-20-2008 at 03:16 PM. |
#23 |
im gonna see if i can afford another turbo. if i can im thinking a t3/t04b or a t28. i may have to go with this turbo for the price im getting it for. I dont think it would be a good idea to spend more money on a bigger turbo and sacrafice money for engine management.
#24 |
so from what im reading, i should spend the extra $ and get gsr cam's and adjustable cam gears.
or at LEAST the cam gears? remember this is kinda a budget i dont really have the extra $ to spend on gsr cams. I HATE MONEY THAT DOESNT GROW ON TREESLast edited by b16stalyun; 04-20-2008 at 10:31 PM. |
| New TURBO GARRETT T4 700.00 OBO | boostedf22 | Parts: For Sale/Trade/Wanted | 6 | 04-08-2008 06:50 AM |
| PA f/s - Garrett t3/t4, kumhos, 18in chrome wheel...misc | loserpunkx182 | Parts: For Sale/Trade/Wanted | 15 | 03-30-2008 04:12 PM |
| Garrett T3/T4 T04E 57 TRIM TURBO! REAL GARRETT! | RSS-Bot | Auctions | 0 | 12-10-2007 02:43 AM |
| Garrett t3t04e .57trim .63ar, 38mm tial, greddy type-s, manifold, EBC...more | a_integra_87 | Parts: For Sale/Trade/Wanted | 3 | 11-16-2006 08:48 PM |
| FS: Garrett t3 turbo | BodyDroppedNikes | Parts: For Sale/Trade/Wanted | 12 | 08-28-2004 12:41 PM |
