| | LinkBack | Thread Tools |
| | #1 |
| Member | I am having a problem with my car staying idled at 1000rpms..It wants to idle up to 2000rpms and some times fluctuates back and forth..I am running a Aem ems management system and I replaced the tps sensor and it Idled fine till I got on it then it comes back..I have made sure the ems is calibrated and that the tps is tight..Someone please help |
| | #4 |
| Member | Well I put a diff Iac on there too..Its stumping me cause everytime I put a tps sensor on I recalibrate the aem ems to it then when it starts to idle high again I go in the aem and look and the tps is reading something diff..Almost like its changing volages on its own..The crank angle sensor or anything in the distributor wouldnt be causing this would it? |
| | #5 |
| Ancient Member Join Date: Apr 2004 Location: New York
iTrader: 1 / 100% Ride: RHD EG6 jrsc b18c :)
Rep Power: 30 | The crank angle sensor should not be doing any of this, but let me ask you this, have you looked at the map sensor, goe into the EMS and check MAP sensor and see if it is reading your TPS voltage, IE, turn the car to the run position but do not start and then while looking at the map sensor Press the throttle and see if the map sensor voltage moves, if it does, then you have the map and the tps plugs switched because if the car is just sitting with the engine off neither the tps nor the map should change voltage.
__________________ 9/1/08 NEW PROJECT RIGHT HAND DRIVE EG6 doing it myself! 6/1/09 RHD on the road, now time for Body Shop 7/10/09 jackson gsr into rhd+hondata 91 rex ls/vtec b18b block, p30 pistons, pr3 head, p72 cams and ecu, 100% OEM HONDA PARTS, 100% converted to obd1 w/del sol harness NO JUMPER! 13.881@102 on street tires Reputation makes the world go round, if anyone has helped you and you feel that their post was worthy of some reptation, then give 'em a point!---, <-------------------------------- |
| | #6 | |
| Member | Quote:
| | #7 |
Rep Power: 30 | Well I guess it wouldn't be possible then if you have a different plug/map setup it's just a common thing when people do a swap is that they mix those 2 plugs up. Other than that I have no clue what the problem is. |
| | #8 |
| Nick Go FAST!! Join Date: Jan 2006 Location: East Burg, PA! Age: 28
iTrader: 3 / 100% Ride: 09 Cobalt SS/TC
Rep Power: 88 | Have you tried adding more fuel around the idle area? My Accord did this, it was the ECT multiplier. When it got hotter it would lean out a lil and make the idle jump. |
| Centrifugical Supercharger Vs Turbo | JDMSpecAccordSir-T | Forced Induction | 49 | 05-24-2007 12:44 PM |
| Turbo Parts for sale | adidas_man | Parts: For Sale/Trade/Wanted | 9 | 06-20-2005 09:55 PM |
| Oil Pressure Problem (Turbo B16A CRX) | turbocrx2.0l | Forced Induction | 10 | 01-28-2004 02:20 PM |
| turbo problem | roach009 | Forced Induction | 1 | 01-22-2004 12:34 AM |
