High Compression & Nitrous
Old 06-06-2003, 11:44 AM   #1
Rep Power: 0 michaelgomez is off the scale
i have a 91 crx si and did a 96 mini me swap along with 89 integra pistons and rods. i heard that the the head will raise compression about a point and that the pistons raise it another 3/4 point. then on top of that i had the block shaved .20 and bored .10. i figured my compression was going to be really high, so i bought a head gasket spacer kit from summit and put on about 1.25 mm. so now i figure my compression is going to be about 10.5-11 to 1. and i've heard alot about high compression and nitrous. and i was wondering if it would raise the compression so high that it will bend a rod or blow a piston, or if it will be ok?
thanks
meeko
michaelgomez is offline   Reply With Quote
Old 06-06-2003, 02:57 PM   #2
Rep Power: 14 hondaguy72 is off the scale
Detonation is the foe. Nitrous, while increasing cylinder pressures (can cause detonation) cools the charge (incoming) air to the point where it actually lessens the possibility of detonation. So as long as you don't run out of fuel and have the timing set correctly, (retarded about 2 degrees per 50hp of shot) high compression and nitrous work together very, very well.
hondaguy72 is offline   Reply With Quote
High compression SLEEVES Elo'rin Engine Building 15 05-13-2004 12:29 AM
Static vs. Effective Compression pissedoffsol Turbo Information 0 01-12-2004 01:43 AM
High Compression Pistons (for C5) ek9r Engine Building 8 09-19-2003 05:59 PM
Rules on high compression and n2o jordan Engine Building 5 09-13-2003 10:51 AM
high compression heads malice93 Engine Building 3 11-04-2002 07:12 AM
