| | #1 |
| Junior Member | Ya i had a idea that poped in my head while reading the homemadeturbo site the idea was a homemade supercharger designed like a vortec supercharger by using the intake half of a turbo mount it to you head in a way that you can center a rod on the spool thing that runs in front of the head to the timing belt and mount that to the other side of the head, put a cam gear on the end of the rod and connect the timing belt to it. and then run a pipe to the intake manafold. After you read this i would like a response from you about if you think it is possible |
| | #2 |
| Senior Member Join Date: Jul 2003 Location: buck teeth and government checks, PA
Rep Power: 52 ![]() | anything is possible but is it worth it? no you'll have more time and money into that thing than a jackson s\c costs and it wont work nearly as well. either buy a turbo or s\c. dont be like that buttdart thats trying to make a turbo for his go cart. |
| | #5 |
| Banned | Reality check: You don't even know the proper names for the parts you're talking about. You have no hope in hell of ever completing what you describe, at least in your current state of automotive and fabricating education. And why the hell would you want a centrifugal supercharger? |
| | #6 | |
| Senior Member Join Date: Jan 2003 Location: Raleigh, NC Age: 22
iTrader: 2 / 100% Ride: 88 Honda Civic HB
Rep Power: 216 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Quote:
the only thing good about the centrifugal sc is you can plumbed a intercooler or aftercooler much more easily that can be done on with the roots sc. | |
| | #7 | |
| Steel Bladder Join Date: Aug 2003 Location: NOT in Indy Age: 27
iTrader: 0 / 0% Ride: JBo!
Rep Power: 485 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() | Quote:
That's the funniest thing I've ever seen... Then you can run the intake pipe to the thing that lets the air flow at certain times but only when you step on that pedal thing in the inside of the car, you know what I mean. and that way...you can have a centrifugal supercharger and don't do any tuning and run an 11 second quarter for 300 dollars! | |
| | #8 | |
| Banned | Quote:
Similar Threads | ||||
| Engine cooling with home made turbo kit | some white guy | Forced Induction | 6 | 04-08-2004 10:13 AM |
| Home Made ITB's.........pretty cool | JDMilan | Engine Building | 18 | 03-16-2004 12:17 AM |
| Was there ever a supercharger made for the ZC | Moon Ill | Forced Induction | 11 | 02-06-2004 09:23 AM |
| Site On Home Made Tubo Kits? | EdrikLongtail | Forced Induction | 1 | 03-29-2003 10:42 AM |
| Home Made Turbos For Zc ? | starboy869 | General Tech and Maintenance | 1 | 03-24-2003 08:30 PM |
