alright i've got everything figured out but this. its a stock single cam non-vtec, my beater and i'm goin to junkyard turbo it. question is how to boost without the ecu detecting. i've heard of so many ways but whats the cheapest cause i could giva shit less about this car, i just wanna boost it. also one alternative was some chip that i heard about on honda-tech, anyone know if i have to upgrade any fuel things if i go with this chip
<u>My JDM, H22, ITR, Turbo'd Integra</u> <a href=\'http://honda-tech.com/zerothread?id=831210\' target=\'_blank\'>click here!</a> <u>project RHD sleeper hatch</u> <a href=\'http://honda-tech.com/zerothread?id=1190974\' target=\'_blank\'>click here!</a> |
Ride: '92 Civic CX
go to the local aquatics store and get about three (3) check valves and put them inline to your map sensor.
Garage: 1992 CX Hatch > Current Money Pit Grave: R.I.P. 1995 Integra GSR R.I.P. 1990 DX Hatch R.I.P. 1990 CRX Si |
#3 | |
A better solution might be just by the missing link check valve for 50$ __________________
"Our enemies are innovative and resourceful, and so are we. They never stop thinking about new ways to harm our country and our people, and neither do we." -The thought provoking George W. Bush |
what am i going to need fuel wise if i use the missing link, could i get by with stock or should i put a pressure regulator on it
#5 |
doesn't change anything fuel wise... you need aftermarket fuel setup for turbo.
#8 |
Nick Go FAST!!
Ride: 09 Cobalt SS/TC
Why do you need a check valve? I thought the stock map sensor is good to 11psi? mine was anyway.
Seriously though, a lot of people told me to do this and I went against it. Get a socketted ecu and run Crome or some other free program. Its cheap and easy to do and the results are incredible compared to a FMU and shit valves etc... __________________
www.BackyardTurbo.com |
#9 |
is lol'ing @ you
Damn this thread is 5 years old. Anyways, I have been told the same things. The factory MAP is good for right around 11psi, and I was also told to never run a missing link.
#10 |
Nick Go FAST!!
LOL, I didnt realize this is an OLD thread LOL!
#11 |
my cars go fast
Ride: ED8
you need the missing link if you dont want a check engine light. its a cosmetically nice version of $3 in check valves. if you run the ML, 12:1 fmu on stock injectors, walbro255 pump at 5psi or less, your car will run rich as hell but it definitely wont blow up/torch pistons and will run forever if you take care of it. thats a common misconception about fmu's. theyre alright for a budget minded booster at very low, basic boost levels, just be prepared for a stinky car that gets the gas mileage of an 18 wheeler. but fuck it! youll be boostin!
#12 |
Administrator
Ride: 318ti, dakota, genesis 2.0t
the stock map sensor is CAPABLE of READING boost to 9 or 10 psi (obd0 / obd1or2), however, the ecu WILL throw a code if it sees more than 2psi ish on it, which is why you need the bypass valve.
OR, a chipped solution (with boost tables, so that it can READ it) under the 9-10 |
#13 | |
you get the BRAKE
As far as bypassing the MAP sensor, just buy a missing link for like 20 bucks and apply it beneath the map sensor. They even come with extended screws to fit into the throttle body. __________________
eg hatch (jdm b16) sold 1999 Yamaha YZF R6 (modded) http://hondaswap.com/engine-building...ow-pics-102486 sold |
#14 | |
honda builder by nature
Ride: Lexus GS400
X2 at least score some DSM 450cc injectors and out a B&M fuel osi regulator on it or it will go bang real fast. Find the missing link on ebay __________________
Proud co-owner of Tri-Tech Motorsports in Phoenix, AZ |
| ECU Pinouts | pissedoffsol | Reference Materials | 4 | 11-21-2007 10:46 AM |
| Crx b16 problems | b18c1civic97 | HYBRID -> ED-EF / DA | 19 | 05-07-2007 02:53 PM |
| 88+ ECU Error Codes | pissedoffsol | Reference Materials | 1 | 05-19-2005 01:03 PM |
| Bypass 2nd O2 Sensor (pr3, Obd0) | Uppertorso | ECU's, Electronics, and Tuning | 1 | 04-19-2003 10:26 AM |
| 85-87 ECU Error Codes | pissedoffsol | Reference Materials | 0 | 09-28-2002 01:29 PM |
