Greenhorn
Hi,
I just wanted to know what you guys think about my turbo setup. I`ve got almost everything together except for a t3 turbine housing. Stock B18C6 GT28RS Synapse ramhorn manifold/downpipe Tial 44mm wastegate HKS ssqv bov Precision 660cc Precision 750hp intercooler Skunk2 68mm throttlebody Skunk2 pro intake mani 68mm Hondata intake gasket GM 3 bar map sensor P28 ECU Digital Boost Controller Apexi AVC-R Aluminium Racing Radiator 1/2 Skunk 2 megapower RR 3" exhaust Fidanza flywheel ACT Stage 1 clutch Going to run 0,5 bar of boost. Goal 300whp |
#2 | |
yep....mmhhm.......yep...
Ride: 92 PRELUDE SI
Stock ecu? And 300whp might be hard with those injectors IMO. My goal is 450whp and the smallest injectors i could get was 780cc. Thats alot of power on stock internalls is this your dd?
Hugh.......I like money....... "idiocracey" Quote:
Greenhorn
Stock integra ecu = P72
It will be tuned with ECtune. 300whp requires 620cc @ 80% duty cycle. So 660cc is plenty for me. Yes, its going to be my dd. I think it will handle 300whp just fine. Stock GSR motors run fine on 8psi with about the same whp. So i think it wont be a problem. |
#4 | |
Ride: 92 PRELUDE SI
300whp is alot. Not saying that it cant be done,just saying to make it reliable even with a good tune you need a built bottom end. I have a boosted jdm h22 in my prelude. 780cc,-7cc dish pistons,eagle h-beam rods and more.... I am only pushing about 270whp. I will be pushing 450-500whp when i do a few more up grades and get a ramhorm mani. I am only pushing 9-11psi boost. I could turn it up way higher but i am going to wait till i beef up my cooling sys. And up grade a few things. I want reliable hp.
#5 | |
Greenhorn
The B-series have stronger sleeves and the head has good flow. The tranny is good aswell. I think it`s quite safe as long as i keep boost to 0,5 bar and not getting it run too lean. Your right about realiability, the engine is in perfect state now. If the engine holds it for 2 years im satisfied because by then it will be rebuild. |
#6 |
wwtdd?
i dont' think you will get there on .5 bar. you may need 1-1.2 bar.
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic. |
#7 |
Ride: '92 Hatch si w/B16 (wannabe EG6)
Seems like high goals with stock bottom end and daily driving.
I could see 250 whp DD....so thats about 300 crank hp. I think its touchy to get to teh 300whp mark but you could prove me wrong. I might be wrong but why does the TB and intake seem HUGE for this desired hp? Or is it you're trying to increase the volume and lower the pressure of air coming into the intake manifold? __________________
"Meow, you know how fast your were going back there?" http://hondaswap.com/hybrid-eg-ek-dc...si-b16-286581/ |
#8 | |
Ride: 92 PRELUDE SI
I have learned"the hard way" once you get to 250-300whp. You have to up-grade just about everything to handle the hp. And making it reliable and fast is that much more of a challenge. Nothing on these cars that is stock is made for that much hp. I have a stage2 cluch as of now. And i will need a new one that is stronger when i re-tune and turn up my boost. Imo. People dont understand how fast 300whp really is in these little cars. Thats fucking scary fast imo. Anything abouve that and no traction w/o further mods.
#9 |
Ride: i have 14 cars i drive my sohc turbo ef
check this out for inspiration PFC Hatch at Import Tuner Mayhem 2009 on Vimeo= i wouldnt do this with my daily but shows you what can be done with a stock engine
SOME PEOPLE ARE LIKE SLINKIES. NOT REALLY GOOD FOR ANYTHING BUT THEY BRING A SMILE TO YOUR FACE WHEN PUSHED DOWN THE STAIRS. |
#10 | |
Greenhorn
#13 | |
my cars go fast
Ride: ED8
imo, your power goal is not unreasonable at all. in fact if youre going to a competent tuner(and i have to assume u are due to the higher-end parts list), 300whp should be pretty easy to find. however, on a stock bottom end, at that output, expecting to get 2 or more reliable years as a dd is kinda foolish. what kind of mileage will u be putting on it daily, and how much of that are u at wot? |
#16 | |
Greenhorn
#17 |
If you are comfortable taking it out, spending the $$$ and switching bottom ends....
no big deal....run 300 tuned whp and have a blast! __________________
#18 |
where do you ppl get your info from??
660cc is more than enough to hit 300whp...i made 350+ using 550cc its all in the tune and a good fmu or fuel pressure regulator.. spend the extra $$ and get some pistons n rods if you like your car..you dont even have to get any of the fancy names unless your gonna go over 350whp.. about 9-12psi shoud hit your goal .. and believe me 300whp is very fast in a integra or civic..enough to land you 12sec with a half decent set up |
#20 |
my stock ls turbo worked great for 6months at 12psi making 380whp then i turned it up to 18psi and made 426hp and it bent a rod a week later
#22 |
yes runing on e85
#24 | |
F.I. Junkie
Ride: 1996 Civic, 1992 Accord
Gotcha, I was going to say that is a lot of power on a stock bottom end. But corn fed, it makes sense
A section is like this for example: General Tech and Maintenance - HondaSwap Forums You don't have to post in there though. There are tons of sections, find the one that best fits your question. Welcome to HS ![]() __________________
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6- |
| questions about rebuilding bottom end with stock components | raceinspiredrex | Civic and CRX - EF | 2 | 05-21-2009 10:40 AM |
| 94-01 acura integra OEM bottom side skirt skirts STOCK | RSS-Bot | Auctions | 0 | 01-09-2008 02:43 PM |
| integra stock bottom end? | motorhead | Forced Induction | 0 | 09-21-2006 01:23 PM |
| WTT: built b16 top and bottom for stock gsr | RIT Civic | Parts: For Sale/Trade/Wanted | 0 | 12-02-2003 04:48 PM |
| stock bottom end | rudeludenotmeanthough | General Tech and Maintenance | 4 | 11-16-2003 09:14 AM |
