LS/Vtec Boost Setup
Old 03-22-2009, 01:08 AM   #1
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
Rep Power: 21 TurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to beholdTurboRex90 is a splendid one to behold
Send a message via AIM to TurboRex90 Send a message via MSN to TurboRex90 myspace  FaceBook
Default LS/Vtec Boost Setup
So im looking into picking up an B18B1 block, and my buddy has a vtec head for me.. he didnt say if it was a B16 or B18 head but im guessing a B16.. anyways..
As far as parts go, im new to B-series.. ive been runnin a single cam D16Z6 on 19psi.. and lookin for some of the same brands for a B-series as i used in my D-series, its hard to find anything.. What brands would you recommend for pistons in the 9:1 or 10:1 CR range, cams, valvetrain etc.. just throw me some brands. Thanks guys!
TurboRex90 is offline   Reply With Quote
Old 03-22-2009, 01:04 PM   #2
austin20110's Avatar
Ride:  96 civic coupe, 05 s2k project car with buddies
Rep Power: 39 austin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud ofaustin20110 has much to be proud of
Send a message via AIM to austin20110
Cp pistons or je pistons
Cams you could do skunk2 stage 2 turbo cams, they seem to be popular LUIS has done alot of research on them. Valve train shold be fine. You might want to sleeve your block, and get some arp head bolts. If your worried about CR you can always get a cometic low compression head gasket.
Originally Posted by packardbell View Post
i plan to modify it to the max and swap out the motor and go fi.
austin20110 is offline   Reply With Quote
Old 03-23-2009, 02:10 AM   #3
Boosted Rex
TurboRex90's Avatar
Ride:  '90 CRX SI
thanks!
Old 03-23-2009, 07:07 PM   #4
civic525whp
LsTec's Avatar
Ride:  '97 EJ8
Rep Power: 5 LsTec will become famous soon enoughLsTec will become famous soon enough
myspace
arias pistons, crower stg cams <---- AMAZING!! eagle rods, sleeve and girdle the block if your putting the time into it or use a deck plate, but or your using a b18 block there shouldn't be a need, manley or ferrera for the valve train
'97 civic EJ8 525whp/343tq @ 13psi
-LS VTEC TURBO
-B18a1 block sleeved to a 2.0, forged, girdled
-B16 A2 port and polished, manley titanium valve train
-Borgwarner Bullseye S362 turbo
-Tial 44mm waste gate
-and on and on and on.........
-Check out some of my dyno vids @
http://members.streetfire.net/profile/wrighteous303.htm
newer vids coming soon....
LsTec is offline   Reply With Quote
Tags
b16, b18, ls vtec
ls vtec setup fredsintegra Integra 3 01-05-2007 12:14 PM
FS: LS/Vtec Setup unix4linux Parts: For Sale/Trade/Wanted 4 06-24-2005 05:36 PM
the best ls/vtec setup is...? SPEEDFREAK0920 Engine Building 15 11-18-2004 02:43 PM
Need help getting new boost setup to START! hybrid89 Forced Induction 5 07-06-2004 02:00 PM
Boost and a dry setup??? Dancomer Forced Induction 2 03-17-2004 12:49 AM
