ls/vtec turbo
Old 12-02-2003, 11:08 AM   #1
Rep Power: 15 typesiracing is off the scale
Send a message via AIM to typesiracing
I'm a believer that a turbo setup can work on any car as long as its tuned right....so i'm planing on boosting an ls/vtec.....i'm going to set the motor up right with oil lines etc...but maybe you guys can recommend pistons, rods, cams, injectors, turbo, and ecu suggestions to me for 275+ whp.....i have a 1.8 block and a b16 head with crower retainers and springs....i know it gets to be expensive but i wanna try and keep the setup between 4-6k not including what i have.....i already have an apexi-vafc. and i know if the power gets too crazy i'm gonna have to get it to the ground so i wanna keep it controllable....thanks for the info.
I'm new to the game but learning quick....thanks for all the help guys!
94 Lude many mods (h23)
94 CX B18b
93 DX with '95 b18c ls/vtec
w/ type r pistons and crower valve train
97 Toyota Tacoma (to transport all my parts)
89 Nissan 240sx (someday project)
typesiracing is offline   Reply With Quote
Old 12-02-2003, 11:33 AM   #2
Rep Power: 18 chingro is off the scale
i have seen many turbo LS/VTEC's
current: 96 integra LS, LS/VTEC, 00 GSR tranny
past: turbo 95 civic, LS/VTEC 92 civic, 91 hatch DOHC nonVTEC swap, LS/VTEC 92 teg, B16A 91 hatch, 91 hatch ZC swap, 91 sedan SOHC VTEC swap, 87 integra rebuilt JDM ZC motor 14.5 all motor, blew up the next day
future: re-live the past, but this time...better
chingro is offline   Reply With Quote
Old 12-08-2003, 04:49 PM   #3
Rep Power: 13 emomelodic is off the scale
Send a message via AIM to emomelodic
hey, what i would do.. and i dont know if this is right cuz im an idiot
but ide use ls pistions, crowler rods, aem cam gears. type r injectors rev hard turbo kit and intercooler and ide make damn sure the oil is getting flow, like type r oil pump action, squirters... and whatnot
a huge problem ive experienced with the ls/vtec is its got balls but its not stable because the ls block maxes out at 7grand and the vtec head is around 9. just make sure you do everything you could do to the internals of the block before you start boosting it.
thanx.
emomelodic is offline   Reply With Quote
Old 12-12-2003, 11:29 AM   #4
thanks for your info. what i was planning on doing is ls crank, crower rods and maybe je pistons.....with the gsr block and the oil squirters which i think are the same as the type r and as suggested a crower turbo cam.
94 CX B18b
Old 12-15-2003, 12:41 AM   #5
Rep Power: 13 exospeed*com is off the scale
The ls block doesnt max out at 7G RPM. we have an LS/VTEC turbo race car doing 9500 RPM shifts
for $4-6G, you can get a great built turbo setup.
Fully built LS bottom end sleeved runs $2800 with Eagle Rods and Arias Pistons.
Tapping the head for LSV setup is $100 includes resurfacing. another $100 gets the Oil lines. HEad gasket and timing belt, another $100.00
Thats about $3100.00 right there.
You have another $900-$2900 left to spend on whatever you like.
Drag turbo kits run $2800.00
There you go. fuly built motor with a nice turbo kit for your budget.
Good luck.
Wil
Exospeed Race Engines/Exospeed Racing Products
<a href=\'http://www.exospeed.com\' target=\'_blank\'>http://www.exospeed.com</a>
exospeedCRX@yahoo.com 818-355-6156
Specializing in:
Custom Race Engines, BLOCK SLEEVING, Head Packages.
Road Wheels, Suspension and more.
D-Series * B-Series * H-Series * ALL MOTOR/Turbo * DRAG/Autocross/ Road Racing / Street
Contact us for Race Engine build consultations.
exospeed*com is offline   Reply With Quote
Old 12-15-2003, 08:09 PM   #6
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
if 275 whp is your goal, i wouldn't bother sleeving. tuned right and non- detonating, your sleeves will hold that just fine.
id sell the vafc, and get a hondata system with some 550 cc injectors.
and spend the money for a tuner and dyno time.
turbo, id go with a t3/t04e .63 a/r 12-14 psi or so should take you to 275 whp on that no problem.
internals, CP pistons are bad ass, but $$$$... JE's are good choice too. rods, crowers and pauters and manleys are $$$$$, but eagle's should hold 275 whp no problem.
if you still have money left over, invest in a quaiffe LSD.
FS - ls/vtec turbo wespirl Parts: For Sale/Trade/Wanted 7 04-28-2004 12:14 PM
LS/Vtec turbo? UDT General Tech and Maintenance 5 11-20-2003 10:53 AM
Is there a Supercharger kit chap_e77 Forced Induction 3 08-26-2003 07:09 PM
Gt4 Y0! pissedoffsol Members' Lounge 33 06-18-2003 01:13 PM
Ls/vtec Or Ls Turbo Civic_88ls Engine Building 8 04-08-2003 10:17 PM
