Map sensor question
Old 05-22-2008, 04:35 AM   #1
Ride:  91' DA Integra
Rep Power: 0 tuner2484 is on a distinguished road
Default Map sensor question
Can you use a 94-01 integra map sensor on a 91 integra? I have a BDL throttle body that has the opening on the bottom for the 94-01 integra map sensor but I have no idea if theres a way to connect my 91 integra's original map sensor harness to the 94-01 one? The reason I'm asking is I found a 4bar map sensor for my turboed teg that fits the BDL throttle body but the sensor has the 94-01 connector and wanted to see your guys input on connecting it.
tuner2484 is offline   Reply With Quote
Old 08-17-2008, 10:46 PM   #2
daGSRhatchNEPA's Avatar
Ride:  93 acura integra
Rep Power: 5 daGSRhatchNEPA will become famous soon enough
Send a message via AIM to daGSRhatchNEPA
do i need a map sensor.. ? it ran fine b4
daGSRhatchNEPA is offline   Reply With Quote
Old 08-20-2008, 11:59 PM   #3
Hondaholic
prpprimo's Avatar
Ride:  91 hatch z6/ 98 coupe z7
Rep Power: 2 prpprimo is on a distinguished road
Send a message via AIM to prpprimo
seeing that a map sensor is required to deliver the right amount of fuel/air. I would think so.
For the most part they all work the same in conjunction with other sensors.
prpprimo is offline   Reply With Quote
Old 08-22-2008, 09:10 PM   #4
Rep Power: 6 amadeuscr will become famous soon enough
I think if you change from stock map to 4bar map , it will not work ok if you don't change it on the ECU !
Ride:
B16A JDM SiR-II - Hatch 92
- WISECO Piston Kit STD
- Eagle Rods
- Walbro 255lph
- AEM Wideband
- CROME PRO
- T3/T4 Turbo Kit - RamHorn Style
- DSM 450cc Injectors
- TiAL 38 MM External WasteGate
- Integra Front Brake System
- Mugen Valve Cover Red
- NGK Iridium Spark Plugs
amadeuscr is offline   Reply With Quote
Forum Jump
O2 sensor question Shaun75 HYBRID -> ED-EF / DA 4 04-19-2007 01:29 PM
o2 sensor question Honda18 HYBRID -> EG-EK / DC 9 05-23-2005 01:21 AM
ecu and o2 sensor question erebunicrx ECU's, Electronics, and Tuning 6 06-15-2004 04:40 PM
o2 sensor question smashed4thgen HYBRID -> ED-EF / DA 0 11-24-2003 12:18 AM
map sensor question??? kell211 ECU's, Electronics, and Tuning 2 10-06-2003 06:59 PM
© 2001-2008 HondaSwap.com
 | a SkeyMedia Network site
