Max Boost on D series
Old 11-01-2005, 10:07 AM   #1
TTIWWOP
reckedracing's Avatar
Ride:  90 z6-t hatch, 94 Bagged S10, 91 Lifted Mazda
Rep Power: 411 reckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
reckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond reputereckedracing has a reputation beyond repute
So I am looking into building up my d series for more boost than a stock map sensor will let me run...
so...
a gm 3 bar map will allow me 2 bar over atmospheric pressure right?
so if i were to use hotrex's block filing method, and got some H beams with some 8:1 or 8.5:1 pistons what do you think i could safely push the motor to? PSI and HP wise
and if i went with rods, pistons, and block filing whats the next weakest link?
edit: what size turbo would be good? and what size injectors?
I'll blow a hole in your face then go inside and sleep like a baby.
reckedracing is offline   Reply With Quote
Old 11-01-2005, 10:08 AM   #2
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
the tranny and axles probably...
and don't go down to 8:1... these are hondas, not nissans. stay above 9, or its going to be a dog off-boost.
safely, i'd guess 350? i dunno...
everything else will start breaking first... lol
Old 11-01-2005, 11:13 AM   #3
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
<div class='quotetop'>QUOTE(pissedoffsol @ Nov 1 2005, 11:08 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
After rods and a block guard, engine wise, I'd say pistons... But this is assuming you are going to use ARP rod bolts. That is a MUST. And 'sol is right, don't go down to 8:1.. There is no need for that.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 11-01-2005, 11:41 AM   #4
Rep Power: 11 CSaddict is off the scale
honestly, the trannt is pretty stout. if you run street tires, the first to go will be axles, if you run slicks, itll be the tranny.
you will make around 300-320 ish on about 20 psi.
i made 293 on 18
CSaddict is offline   Reply With Quote
Old 11-01-2005, 11:42 AM   #5
Rep Power: 19 kaoskustoms is off the scale
Send a message via Yahoo to kaoskustoms
deff the tranny axle issue they are pretty week then valves and springs rettainers they wont hold a poo load off boost
honda the replacment for displacment
ummmmm vtec
kaoskustoms is offline   Reply With Quote
Old 11-01-2005, 11:42 AM   #6
btw this is hotrex posting on daves name by accident
Old 11-01-2005, 11:45 AM   #7
TTIWWOP
<div class='quotetop'>QUOTE</div><div class='quotemain'>then valves and springs rettainers they wont hold a poo load off boost[/b][/quote]
i;m not sure i understand how the retainers will be affected by boost?
and what size injectors would you guys recommend?
Old 11-01-2005, 11:54 AM   #8
Rep Power: 14 hotrex is off the scale
they wont be... they have nothing to do with that.
that will only allow you to rev further up the power band..
you can mae oodles of power on stock head components.
id roll some 550s in nyour d series. you will not use more fuel than they can provide. plus they still idle descent.
www.cc-fab.net
for all your turbo manifold and charge piping needs,
hotrex is offline   Reply With Quote
