Which Motor? Pls Help!!!
Old 09-23-2009, 12:16 AM   #1
Greenhorn
Rep Power: 0 Lawrie is on a distinguished road
Default Which Motor? Pls Help!!!
I'm new to Vtec motors and looking for advice before I start my next project.
Looking at either a B series or K series motor for the car. I am thinking of going all out and putting a turbo on the motor as well.
After having a bit of a look around the net I believe the B series motor might be the better option bang for buck, but what about throwing a turbo on it? which motor is more receptive to a turbo? would be happy with around 300 - 350 whp...
Thanks in advance.
Lawrie is offline   Reply With Quote
Old 09-23-2009, 12:20 AM   #2
My name is Byron.
efhondakid's Avatar
Ride:  89' DX Hatch w/B16
Rep Power: 222 efhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
efhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond reputeefhondakid has a reputation beyond repute
Regardless of the donor car the B swap will be the cheapest and easiest, and 300-350 is pretty easily attained on a boosted B.
^ (dont listen)
There is a hidden message here.
"Motor swaps, turbo kit installs, diagnostics, minor repairs, minor fab and bodywork. Located in Akron-Canton area PM me for more details."
"In the dice game of life who gets the last roll?"
Old 09-23-2009, 12:20 AM   #3
AHHVTEC's Avatar
well if you just want 300whp then i say stick with the b series, and i would prolly go with a b18b1 or b18c1. the b1 will have lower compression but less hp, abd the c1 is high compression but with more hp, but remeber its all in the tune after you go turbo.
Old 09-23-2009, 01:35 AM   #4
HS Troll...And Mod
reikoshea's Avatar
Ride:  2001 Honda S2000
myspace
b18b1, upgrade the cams to something more suited to a turbo, and get it tuned. you should be just fine. Its the cheaper way to go in the long run and you still get good results out of it.
Anime Informant
reikoshea is offline   Reply With Quote
Old 09-23-2009, 10:18 PM   #5
Greenhorn
Ok B18B1 it is... Should I build the bottom end or bolt on the turbo and hope for the best? Also what turbo would be best? what boost would be required? it's going into a circuit car so I want the power to be useable and not all at the top of the RPM range...
Thanks again for your help.
Old 09-24-2009, 01:04 PM   #6
F.I. Junkie
Ride:  1996 Civic, 1992 Accord
Rep Power: 101 Matts96HB has a reputation beyond repute
Matts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond reputeMatts96HB has a reputation beyond repute
Send a message via MSN to Matts96HB
If you want a usable powerband with the turbo on the car, you're going to need some help in the gearing department. My suggestion is this setup:
B18B1 - Stock bottom end, decent valvetrain and cams, decent headwork.
B16 transmission
A 57 trim t3/t4 - These are excellent turbo's for the street/track because they spool decently quick and still carry the car all the way through the RPM range.
Manifold/charge piping/bov/wastegate etc is all your choice, but I would DEFINITELY get a quality turbo and wastegate.
XBOX LIVE GT: teb00stcat (00's are zeroes)
-320 WHP EJ6-
Matts96HB is offline   Reply With Quote
Old 09-24-2009, 01:05 PM   #7
wwtdd?
95b16coupe's Avatar
Rep Power: 215 95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute95b16coupe has a reputation beyond repute
have you ever DRIVEN a 300 hp civic?
Warning: If you are reading this then this warning is for you. Every word you read of this useless fine print is another second off your life. Don't you have other things to do? Is your life so empty that you honestly can't think of a better way to spend these moments? Get out of your apartment. Meet a member of the opposite sex. Stop the excessive shopping and masturbation. Quit your job. Start a fight. Prove you're alive. If you don't claim your humanity you will become a statistic.
95b16coupe is offline   Reply With Quote
Old 10-04-2009, 07:21 PM   #8
Greenhorn
Well it's not actually going in a civic, it's going in a mini cooper... I do know how to drive if that was your concern, I have owned heaps of fast cars, the biggest hp coming from a 1000hp LS2 twin turbo.
Also thanks to everyone elses responses. I am actually going to do internals as well so the engine actually lasts...
Cheers
Old 10-04-2009, 09:42 PM   #9
HS Troll...And Mod
reikoshea's Avatar
myspace
Cheers
I'm going to let jeremy clarkson respond to this (things for finally giving me a reason to clip this episode):
Dunno why it sucks so bad on youtube.
Anime Informant
Old 10-04-2009, 09:46 PM   #10
AHHVTEC's Avatar
rolf
Old 10-05-2009, 06:44 AM   #11
Greenhorn
Originally Posted by reikoshea View Post
i'm going to let jeremy clarkson respond to this (things for finally giving me a reason to clip this episode):
dunno why it sucks so bad on youtube.
i completely agree with you, high horsepower fwd cars are just plain dumb!.
Old 10-05-2009, 06:47 AM   #12
Greenhorn
Luckily I am putting a B turbo in the following-
New Page 1
Old 10-07-2009, 10:06 PM   #13
99sidude's Avatar
Ride:  gsr-jrsc eg hatch, itr ek, 96 maxima se 5mt
Rep Power: 50 99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of99sidude has much to be proud of
Send a message via AIM to 99sidude
woa shit! that is going to be disgusting! I mean that in a good way. I can't wait to see the results.
Originally Posted by Celerity View Post
The worst thing that car ever had installed was your lying two-bit fat ass in the left seat.
My Build: http://hondaswap.com/auto-multi-medi...sc-buld-94841/
93' dx hatch
jdm b18c - jrsc 8psi
s300 440cc RC's
99sidude is offline   Reply With Quote
Old 10-09-2009, 11:48 PM   #14
Greenhorn
Ok, Since the car will no doubt be thrown around a track for 30+ mins at a time I really have to think about reliability...
I've decided I will do a rebuild with new pistons, rods and crank (if i should). I'll also throw on an intake, injectors, valve springs, valves etc. as needed to support the turbo.
I am thinking of going away from the B18B1 and going for a B18C VTEC...
What I want to ask is which B18 VTEC long motor I should pick up as a base? is there no real difference as I am going to throw low compression pistons etc. in what ever I get... Is the bottom end and head ultimately the same???
Thanks in advance and apologies if any of the above sounds silly, new to vtec...
Cheers
Old 10-10-2009, 12:12 AM   #15
Brutal Moderator
BrutalB83's Avatar
Ride:  97 Integra LS Coupe
myspace
There's really only two choices to begin with, either the GS-R or the Type R. The Type R has higher compression and some factory upgrades in the head. It's really meant to be an N/A screamer, so if you're planning on dropping the compression and boosting, just go with the GS-R (B18C1)...
PSN Network ID: BrutalB83
Old 10-10-2009, 12:43 PM   #16
My name is Byron.
efhondakid's Avatar
My friend put the bolt on Greddy kit on his GS-R, he only made 234 to the wheels but i was an all stock motor.
^ (dont listen)
Old 10-10-2009, 01:34 PM   #17
Ride:  i go to towers every friday wit my girl and to us 27 to race
Rep Power: 1 egfreak is on a distinguished road
every one uses ls motors get a type r head a borgd b20b block and crowler cams an forged pistons with a gsr crank on boost will mop any car you c around you and then if you can or want get a ctr tranny those gear ratios are insane trust me i had it in my eg hatch and i was killing porschs an high end cars
egfreak is offline   Reply With Quote
Old 10-10-2009, 05:08 PM   #18
My name is Byron.
efhondakid's Avatar
^ (dont listen)
Old 10-10-2009, 05:24 PM   #19
HS Troll...And Mod
reikoshea's Avatar
myspace
im planning on borging my f20c out and installing crowler cams too. maybe i can mop any car i c.
Anime Informant
Old 10-28-2009, 11:41 PM   #20
Greenhorn
Rep Power: 0 QuoteWarz is on a distinguished road
I have always like the idea of a turbocharged K-series in a really lightweight hatchback or something. I also saw some pics of the V6 motor swapped in as well which would be amazing with the torque.
QuoteWarz is offline   Reply With Quote
Old 10-29-2009, 01:48 AM   #21
Christmas Car
Ride:  93 4dr D15B, Greddy Short Ram, 4-2-1 Header, 2.5" Exhaust.
Rep Power: 8 RoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura aboutRoughKnight has a spectacular aura about
If you are going to do a rebuild, then getting the ITR is a waste considering you are buying it for its higher than normal comp pistons and such. If that is the case, get the gsr. You'll be happier financially, and since you are just replacing the innards you dont have to worry about anything else. Just my $0.02
Please direct your questions in the following format.
1) Did I search it on Google?
2) Did I use the search function in the TOP RIGHT AREA of this page?
3) Refer to Step 1 and 2.
If that doesn't work, then feel free to post.
RoughKnight is offline   Reply With Quote
WTB b18c1/b16 motor and any d series motor with trans!!! Also need a uncut gsr crank tofasttoslowforyou Parts: For Sale/Trade/Wanted 0 04-25-2009 10:24 PM
b18c complete motor 5 speed ecm motor swap RSS-Bot Auctions 0 01-05-2009 02:03 PM
JDM GSR motor w/ auto tranny, motor mount problems balkey HYBRID -> EG-EK / DC 4 10-30-2008 09:08 PM
Acura Integra B18B1 Motor swap Tranny, ecu,motor 5spd RSS-Bot Auctions 0 11-11-2007 08:13 PM
I have a 99si motor and trans i want to have a nice reliable motor in my DD and have orangeracer Engine Building 17 07-20-2007 05:22 PM
