Oil Preasure on t04E (t3/t4)
amadeuscr
I Installed my Turbo and oil is coming out from the exhaust side of the turbo ( of course is smoking ) I think is a lot of pressure , does anyone knows how many psi of oil it should be ?
I checked the line to the oil pan and it's fine !
thanks in advance .
If you are running a ebay turbo you will need to run an oil restrictor type of turbo oil inlet flange.on the supply side. The other choice is to use a -3 oil line which will restrict the oil flow enough to solve the problem most of the time.
Not a problem...good luck with getting it going...
