oil for the turbo/motor
Old 12-10-2003, 11:04 PM   #1
Rep Power: 19 civic15.8 is off the scale
Send a message via AIM to civic15.8 Send a message via MSN to civic15.8
ok, I talked to a guy tonight that had a turbo on his car. And he said to make sure i run un-detergent oil with my turbo. I dont know much about oil and i have never heard of un-detergent oil before. So is this type of oil real? Did this guy know what he was talking about? And whether its true or not what kind of oil would be the best? I heard mobil 1 and castrol gtx are the best? thanks in advance.
bagged and dragin
civic15.8 is offline   Reply With Quote
Old 12-10-2003, 11:24 PM   #2
2265787829
2000Si's Avatar
Ride:  Refer to my name, dumbass.
Rep Power: 285 2000Si has a reputation beyond repute2000Si has a reputation beyond repute
2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute2000Si has a reputation beyond repute
I never heard of that before either. Maybe he was talking about oils that have different types of additives in it that will end up gunking up the shaft and ball bearings in turbos and cause them to break.
XBL: jams 8201 (14,580G)
Lego Sears Tower: 82 stories/75.9% complete
CL2, CL3, CL4, CL5, CL6, Car, Mortgage
Originally Posted by eg6sir View Post
yea.. but aren't you spaghetti noodles covered in skin?
2000Si is offline   Reply With Quote
Old 12-10-2003, 11:26 PM   #3
swanny's Avatar
Rep Power: 50 swanny is on a distinguished road
Send a message via AIM to swanny
damn near all oils have detergents in them, just real the labels and they should say wether or not it contains them.
http://www.midwesthybrid.com
swanny is offline   Reply With Quote
Old 12-10-2003, 11:37 PM   #4
this is why he told me to get the undetergent kind:
cause they regular kind flows best and it will flow to fast for the bearings and it will screw them up so i need to get the un-detergent kind so it flows slower.
i will look at the oils labels and see what kind it is. i just dont want to get some piece of junk oil (if there even is some piece of junk oil)
bagged and dragin
Old 12-11-2003, 01:36 AM   #5
Rep Power: 35 NotUrAverage_Si is off the scale
synthetic oil works good like castrol gtx.
'00 <span style=\"color:black\">FBP</span> Civic <span style=\"color:red\">Si</span>-T
|<a href=\"http://www.full-race.com\" target=\"_blank\">full-race</a>|<a href=\"http://www.goldeneaglemfg.com\" target=\"_blank\">golden eagle</a>|<a href=\"http://www.fast-turbo.com\" target=\"_blank\">fast-turbo</a>|<a href=\"http://www.hondata.com\" target=\"_blank\">hondata</a>|<a href=\"http://www.wiredspeed.com\" target=\"_blank\">wiredspeedlab</a>|
email: boostfedEM1@yahoo.com
<div class=\'quotetop\'>QUOTE(dohch22a4 @ Sep 20 2004, 11:44 AM)</div><div class=\'quotemain\'> Please, Obi Wan B, you're our only hope.
</div>
<span style=\"font-size:36pt;line-height:100%\"> <a href=\"http://www.nissantech.com\" target=\"_blank\">www.NissanTech.co m</a></span>
NotUrAverage_Si is offline   Reply With Quote
Old 12-11-2003, 01:53 AM   #6
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
syntec blend is whats going in my motor if it ever runs
Old 12-11-2003, 02:37 AM   #7
Rep Power: 29 knowledge is off the scale
Redline synthetic oil! Thats what I am running. I ran Royal Purple before that.
The C5 is strong with this one........
knowledge is offline   Reply With Quote
Old 12-11-2003, 02:41 AM   #8
Rep Power: 24 Accordturbo94 is off the scale
There is Such things as non detergent oils. I used them in my Karts after a rebuild to break them in. I know some eurpean turbo cars recommend using a non detergent oil. But the thing with not having the detergents are that sludge can build up and what not. using a regular motor oil removes the sludge before it gets bad and helps prevent them. You may want to use a synthetic oil maybe a bit thicker than normal to help it not break down.. or check out AmsOil they make a specific turbo formula! Va-La my 2c
Accordturbo94 is offline   Reply With Quote
Old 12-11-2003, 09:48 AM   #9
allright thanks guys i think i will either go with synthetic oil or that oil accordturbo94 was talking about (amsoil) thanks alot
bagged and dragin
Old 12-11-2003, 10:01 AM   #10
Ride:  '92 Civic CX
Rep Power: 39 D See 2 is an unknown quantity at this point
Send a message via AIM to D See 2
mobil1 synthetic claims engines properly broke in will show no signs of wear after 200,000 miles
Garage:
1992 CX Hatch > Current Money Pit
Grave:
R.I.P. 1995 Integra GSR
R.I.P. 1990 DX Hatch
R.I.P. 1990 CRX Si
D See 2 is offline   Reply With Quote
Old 12-11-2003, 06:53 PM   #11
Rep Power: 15 BrahmaBullSQ is off the scale
Send a message via AIM to BrahmaBullSQ
MOBIL One If F1 uses it... shouldn't you?
AMSOIL - I run that in my stock CX hatchback. I forget how long it'll last.... I believe like 3 months without changing maybe. I know it lasts longer and is just as good as Mobil and Castrol. Expect to pay more for it though.
<span style=\'font-family:Arial\'><span style=\'font-size:9pt;line-height:100%\'>Dynamic Motorsports <span style=\'color:red\'>(www.dmspower.com)</span></span></span>
My Brother - 359 wheel hp (1.6L B16) - 18 psi
Talbert - 525 wheel hp (2.1L block/B16 head) - 25 psi
b16ahatch - 331 wheel hp (1.6L B16) - 14 psi
&quot;Life is not worth living if one cannot do what one likes most.&quot; - Soichiro Honda
&quot;SCs have their place- low RPM, high torque applications such as two stroke diesels found in cranes and graders. Turbos do too- under the hood of a car owned by anyone that's serious about going fast.&quot; - LocoHonkey
BrahmaBullSQ is offline   Reply With Quote
Old 12-12-2003, 06:19 AM   #12
Mobil1=the worst synthetic out there
Old 12-12-2003, 06:31 AM   #13
How do you figure. My brother has used it in his B16 boosting 18 psi for a year now.
He just now started to leak coolant though. That's been his first problem so far.
Old 12-12-2003, 06:55 AM   #14
Give it time!
Old 12-12-2003, 03:50 PM   #15
Give me reasons. Your analysis of future problems if you will.
I just wanna know what's so bad about Mobil 1. Thanks.
Old 12-12-2003, 04:52 PM   #16
about a year or so ago someone on here found a place that did a test on different types of oil(dino-vs-synthetic) and different brands -vs- one another. I am not saying mobil1 is the crappiest oil ever. It still is better than running dino oil. What i am saying is that out of synthetics, Mobil1 is the worst. Do some research. I would rather spend the money and get the best when it comes to oil, that is all!
Old 12-12-2003, 10:02 PM   #17
I know AMSOIL tested Mobil 1 in their own magazine... it had maybe 6 or 7 tests included and I think Amsoil beat Mobil 1 in all but one. More than likely it was biased and it wasn't showing EVERY test. But I don't think I have the mag anymore.
Old 12-13-2003, 03:15 AM   #18
Slo86GT's Avatar
Rep Power: 48 Slo86GT is an unknown quantity at this point
Send a message via AIM to Slo86GT Send a message via MSN to Slo86GT Send a message via Yahoo to Slo86GT
I PLAN on changing and rebuilding mine so much that I jsut put in 10w-30 castrol GTX. Fuck it, I don't rock anything longer than 50k without tearing up something major or selling it.
- Jody -
2004 Colorado ZQ8 - I5, M5, Regular cab - 209.9whp/210.7wtq
1986 Mustang GT - V8, M5 - 213.0whp/279.2wtq
Slo86GT is offline   Reply With Quote
Old 12-13-2003, 07:27 AM   #19
RETIRED
50k??? has your civic seen mroe than 5k since i've known you bro? lol
