?perfect a/f?
Old 10-29-2009, 09:14 PM   #1
CivEX_00's Avatar
Rep Power: 4 CivEX_00 is on a distinguished road
Default ?perfect a/f?
so i have always been told 14.7 a/f is the ideal amount but today my friend tells me this guy he knows who has a redline with aftermarket fuel parts and pullly for his super charged ion. he says 14.7 is to lean and that my friends talon should be running 10.5-11.5 a/f? is this correct or is this guy high? or is it different turbo>superchargers
CivEX_00 is offline   Reply With Quote
Old 10-29-2009, 09:17 PM   #2
!!YTINASNI
phyregod's Avatar
Ride:  '06 Element , '07 CBR 1000rr, '91 CRX, '98 jeep GC 4x4
Rep Power: 413 phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
phyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond reputephyregod has a reputation beyond repute
myspace
With a turbo/supercharger/boost application, rich is safe. 10 is overkill. 12 should work beautifully. Always err on the side of rich though. Fouled plugs are cheaper to replace than engines.
aleaf.CRX: I've never had steering this bad on a vehicle before. I'm afraid it's going to jump in the other lane and attack someone
reckedracing: PIIDB for jesus
Old 10-29-2009, 09:21 PM   #3
B
Administrator
B's Avatar
Ride:  318ti, dakota, genesis 2.0t
Rep Power: 403 B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
B has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond reputeB has a reputation beyond repute
myspace  FaceBook
14.7:1 is stoich.
low 14's- high 13's is good for all motor
right around 12:1 is good for turbo.
10 is pig rich, wastes fuel, and robs power.
Originally Posted by Airjockie View Post
I got plenty of duck tape, but no penguin tape...
B is offline   Reply With Quote
Old Yesterday, 01:42 PM   #4
RidetilldeathdousparT
pooksy64's Avatar
Ride:  95 EG coupe, 95 Supra , 05' CBR RR
Rep Power: 3 pooksy64 is on a distinguished road
Send a message via Yahoo to pooksy64
---yes 14.7 is stoich which is stock on all cars. and also tru all cars have a preset A/F ratio table on WOT (stands for wide open throttle<--for noobs) when WOT is hit the vehicle ecu will turn to a preset fuel and A/F table which will run slightly richer(below 14.7:1)
Originally Posted by B View Post
14.7:1 is stoich.
---why is lean only good all motor?
12:1 A/F ratio is slightly richer yes which aids in knock/detonation/& preignition)
All motor is basically the same as forced induction in a way.
all motor--> run higher compression pistons (EX : 14:1 compession ratio pistons)so the engine will compress more air on its own thus more power.
forced induction--> run lower compression pistons (EX : 8:1 compession ratio pistons) so it will compensate for all the air that is being forced into the engine.
--> both motors are trying to compess as much air as possible more air+ more fuel= more HP
you run lean yes you will create more HP no doubt.
LEAN condition-- higher cyl temp. cause preignition/ detonation..basically more of a risk of damaging engine internals frm heat.
you run rich yes it is safer, cyl temp is lower.
basically A/F ratio is to keep the engine running @ the target HP you plan (EX:500HP) safely.
remember to *rich you will washboard the cyl walls to *lean overheat.
i think i said to much
ridetilldeathdouspart
pooksy64 is offline   Reply With Quote
Tags
super, super charger, turbo
idling perfect but ... natecspecr HYBRID -> EG-EK / DC 4 08-20-2005 01:16 AM
Perfect shirt for B! Calesta Members' Lounge 14 01-28-2004 06:12 AM
97 GSR Tranny Perfect H22DelSol Parts: For Sale/Trade/Wanted 3 01-17-2004 11:36 PM
Perfect Ecu For Ls/t ls5gen ECU's, Electronics, and Tuning 2 02-12-2003 03:05 PM
Perfect example of my work! Havok Members' Lounge 6 10-09-2002 02:36 PM
