piston rings
Old 01-09-2004, 01:50 AM   #1
Rep Power: 14 t3t4si is off the scale
Ok recently i've run into a few problems with my car. With the rings in cylinders 3 and 4 frying. I have had no cylinder wall scaring. However there is a hot spot but thats nothing a little honeing cant fix. But i am faced with the problem of rings. I have all the items to get the car running again except for rings. I am going to use the factory cast pistons. I have purchased a thicker headgasket to lower the overall compression around one whole point. I would like some aftermarket rings which would seal a little better than the factory ones. Can anyone help me out in this situation?
t3t4si is offline   Reply With Quote
Old 01-09-2004, 02:02 AM   #2
OH yea i forgot to mention i was boosting 9 to 10 psi when the rings went. I do not plan to boost any more than that.
Old 01-09-2004, 02:20 AM   #3
RETIRED
pissedoffsol's Avatar
Ride:  Electric Scooter
Rep Power: 532 pissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to beholdpissedoffsol is a splendid one to behold
one point is usually .1
in otherwords, next to nothing. you won't find a headgasket that drops you a full 10:1 to 9:1 for example. no way. if you do, your motor is going to suck for power...
anyway, rings are rngs really. id just get another set of the oem rings, and bring that and your bock to a machine shop. have them hone your block to match your rings perfectly, that way you don't get leaks or hot spots.
Old 01-09-2004, 03:32 AM   #4
Admin with a big stick
Calesta's Avatar
Ride:  2003 S2000
Rep Power: 379 Calesta has a reputation beyond repute
Calesta has a reputation beyond reputeCalesta has a reputation beyond repute
You can get pretty damn close...
When I was spec'ing out pistons for my new build, just going from a standard 0.030in gasket to a 0.050in gasket took the compression from 13.8:1 down to 12.9:1. That's almost a full compression point right there. On a lower compression engine though (turbo compression levels), you would have to get something almost 50% thicker than that to lower an entire point.
Old 01-09-2004, 04:07 AM   #5
RETIRED
he said he was stock... so i assumed a stock 10:1 compression ratio...
Old 01-09-2004, 05:19 PM   #6
Rep Power: 13 shootNOS is off the scale
i know this isnt my thread but what are hot spots?i'm just trying to know every lil thing about engines
shootNOS is offline   Reply With Quote
Old 01-09-2004, 10:23 PM   #7
Rep Power: 36 NotUrAverage_Si is off the scale
hot spots = not good. discolored areas on cylinder walls, rotors, etc.
NotUrAverage_Si is offline   Reply With Quote
Old 01-09-2004, 11:13 PM   #8
Rep Power: 21 lude68 is off the scale
get some total seal rings!
lude68 is offline   Reply With Quote
installing piston rings saturn_boy96 General Tech and Maintenance 5 09-17-2003 01:28 PM
WTB... piston rings for .25 over DA69 Parts: For Sale/Trade/Wanted 4 08-15-2003 11:34 AM
Piston Rings? wildbillhatchbac Engine Building 11 05-08-2003 05:21 PM
Will It Fit? Piston Rings? Liquidblaze Engine Building 0 03-13-2003 02:23 PM
Piston Rings Liquidblaze Engine Building 1 03-03-2003 08:36 AM
